new format (Micrografx Designer)
eric10600
#1 Post by eric10600 »
I've made a new filter for the Micrographx Designer format. The extension is DRW (which is already used by another software)
I've identified the fingerprint of this format. It seems to be very simple. On 3 differents files, the hexadecimal dumps give in the header:
0000000 ff01 0402 0203 0200 0202 0521 0400 ff01
0000010 ff03 0200 000a 0800 xxxx xxxx (those parts are different)
there is no specific footer.
First I've added this in a new file_drw2.c (based on the template):
  static const unsigned char DRW2_header[24]=  {
    0xff, 0x01, 0x04, 0x02, 0x02, 0x03, 0x02, 0x00, 0x02, 0x02, 0x05, 0x21, 0x04, 0x00, 0xff, 0x01, 0xff, 0x03, 0x02, 0x00, 0x00, 0x0a, 0x08, 0x00
I've compiled it, but it didn't work. So I've used the -C option in hexdump. Now I see every hexadecimal parts are "swapped" (ff01 becomes 01 ff)
This part is now correct:
static void register_header_check_drw(file_stat_t *file_stat)
  static const unsigned char drw_header[8]=  {
    0x01, 0xff, 0x02, 0x04, 0x03, 0x02, 0x00, 0x02
(I've only set 8 elements for this second try, maybe I should increase this number for a better recognison).
Now my question is, for proposing a pull request in github for an official inclusion, what is the best for the file naming? Label it file_drw2.c for example?
Re: new format (Micrografx Designer)
file_drw2.c is OK.
Please provide some file samples. It may be possible to identify the filesize.
eric10600
#3 Post by eric10600 »
great.
I've made it and created the pull request there: https://github.com/cgsecurity/testdisk/pull/100
About some samples, there are a few in this archive:
https://archive.org/download/micrografx ... signer.zip
in the BEISPIEL folder.
i've used them to make some hexdump and noticed some differences sometimes after the 16th byte. Therefore I've only set the first 14 ones in the file_drw2.c
eric10600
#4 Post by eric10600 »
I've noticed some legit DRW files can have some differences after the 8th byte as well, for example:
00000000  01 ff 02 04 03 02 00 02  02 02 21 05 00
00000000  01 ff 02 04 03 02 00 02  00 02 21 05 00
I can't disclose the examples because one of them is private, the other one is from the BEISPIEL folder.
On 4000 found drw files from the 8 first bytes, only 7 files had a single difference after the 8th byte. But maybe those files were damaged (or it's from different versions)...
I've changed the code to only check with the 8 first bytes, it should be sufficent.
