Trying to recover some raw images. I’m struggling with a couple of things...
after choosing the external drive it says ‘write access for this media is not available’
the files are coming up in red.
I can copy said red files into my desktop or downloads... circa 10k photos, yet when I try to find them they aren’t anywhere to be seen.
Should I use photorec instead? Is it the same process? I’m totally new to this and trying to figure it out using YouTube but I can’t find the answers to these particulars.
Please help. Posted it reddit not resolved. Please share your views on it
Re: recover some raw images
Read the manual:
Check the only wikis for Testdisk and Photorec
https://www.cgsecurity.org/wiki/PhotoRec
Try to deliver a precise description.
Read the forum posts to discover the difference between a good and a bad problem description.
