TestDisk file copy progress does it show number of files or sectors?
NicoFish
#1 Post by NicoFish »
Hello I have a fairly simple question.
I have included my the text from my console below. Where it says "119551 ok, 31251 failed" is 119552 the total number of files that have been successfully copied?
My fear is that this is number of sectors copied in which case I have 2822180857 sectors total and at the current rate I will never (within a couple of days) finish.
     MS Data               1051289600 3873470456 2822180857 [Data]
Copying, please wait... 119551 ok, 31251 failed
Thank you for your help.
NicoFish
Re: TestDisk file copy progress does it show number of files or sectors?
Yes.
