Photorec in windows: no such file opening from another folder?
Hello everyone,
I'm trying to recover files from a e01 file from command line.
From 7.1 release, if the file isn't in program directory (photorec_win.exe <file.e01 with path>), I can't open it (no such file or directory).
With old 7.0 release the command work correctly.
Another question: can the gui version (qphotorec_win.exe) open e01 file?
Thank you
Thank you
Re: Photorec in windows: no such file opening from another folder?
I doubt that. Try 7.2 WIP anway. If your path contains space symbols you would need to use the "-symbol to delimit the path string. Right issues may play a role. Try to simplify your problem. Shorten the name of the e01-file, put the Testdisk folder content into the location where your e01-file resides so that stating a path is not needed.betto68 wrote: 17 May 2021, 17:55 Hello everyone,
No.Another question: can the gui version (qphotorec_win.exe) open e01 file?
recuperation wrote: 17 May 2021, 19:16 I doubt that. Try 7.2 WIP anway. If your path contains space symbols you would need to use the "-symbol to delimit the path string. Right issues may play a role. Try to simplify your problem. Shorten the name of the e01-file, put the Testdisk folder content into the location where your e01-file resides so that stating a path is not needed.
Thank you for your reply!
I've tried to delimit path with "-symbol, but never change..
With e01 data and programs in the same directory, it work.. but I would like to keep it in different folder.. with 7.0 it was possible!
7.1 and 7.2 give same problem...
Thank you
What you describe is not sufficient to eliminate a possible error in code. A detailed error description is needed that shows the questions and answers on command line level. The way you describe nobody will take care of it.
Ok: in windows 10, I have photorec in a directory named "d:\testdisk-7.2-WIP", an image file in a directory named "d:\data".recuperation wrote: 17 May 2021, 19:33 What you describe is not sufficient to eliminate a possible error in code. A detailed error description is needed that shows the questions and answers on command line level. The way you describe nobody will take care of it.
From PowerShell (as Administrator):
D:\testdisk-7.2-WIP> .\photorec_win.exe D:\data\image.e01Code: Select all
Unable to open file or device D:\data\image.E01: No such file or directoryIf I move image.e01 in testdisk-7.2-WIP directory, this command work:
D:\testdisk-7.2-WIP> .\photorec_win.exe .\image.e01-
What does .\ stands for?
When being in the Testdisk folder wanting to call an executable just writing "photorec_win.exe" should be OK.
Windows PowerShell doesn't load commands from the current location by default. ".\" is current locationrecuperation wrote: 18 May 2021, 11:07 What does .\ stands for?
Please try out if you face the same problems when using the standard shell "cmd.exe".
Yes: I have already tried.. it doesn't change anything.. (".\" can be omitted in this case)recuperation wrote: 18 May 2021, 18:34 Please try out if you face the same problems when using the standard shell "cmd.exe".
What is the command, what is the error message?
