i have a Problem with the restore of my passwords.kdbx file. I cant find it. All other files like *.docx, *.pdf, *.jpg are restore succesfully but not ma Keepass Files.
Please help!
Best Regards
Markus
Keepass File *.kdbx Recovery Topic is solved
Re: Keepass File *.kdbx Recovery
Can you send me 3 .kdbx files samples ? I will check what the differences are between .kdb and .kdbx files.
I'm also looking to recover a KeePass2 .kdbx file. I've attached a zip file with 3 samples. Any help in creating a signature would be greatly appreciated!
Thanks!
Thanks!
- KeePass2_kdbx.zip
- KeePass2 *.kdbx files
- (6.07 KiB) Downloaded 1212 times
I have uploaded a new 6.14-WIP version. Can you try it ?
Thanks, but unfortunately I ended up with one enormous (300Gb+) .kdbx file.
Any thoughts? I sincerely appreciate your time and effort!
Thanks again!
Thanks again!
Keep all file format enabled. This way PhotoRec will stop the recovery of the kdbx file when a new file is found.
Thank you!!
Between the file recovered by Photorec, and the repair option in Keepass, I was able to successfully restore all of the info. A donation will certainly be headed your way this week!
Again, thanks for your effort and assistance - it's sincerely appreciated!
