Am I out of luck?
iBison
Am I out of luck?
#1 Post by iBison »
Laptop was dropped, when not running. This is what I am getting. When I scan the drive it shows the folders, but the documents and settings folder is empty. When I do a deep scan it fails before it completes. I on really need the files from the user account in D and S. It makes it through about 4% of a 500gb drive with some errors before it fails.
Re: Am I out of luck?
Read the forum roles above in reddish color:
Other people are using the search function actively!
As for your question, my crystal ball is in repair so I can't answer it.
If you want answers, ask a specific question.
Your title is as bad as this one:
viewtopic.php?f=7&t=11253
Typically I don't answer such questions. You were lucky that your post has not been ignored.
The body of your request text is good.
