I have a Samsung NTSF HD that has become corrupted. TestDisk finds the partition and all the folders/files except those hidden by a program made by FSPro Lab:
https://fspro.net/hide-folders/
The tree below shows the expected folder structure. Most file recovery programs (Recuva, etc) easily find this hidden folder and contents, but TestDisk doesn't and this surprises me. Photo Rec finds the files for sure but identity and folder structure is lost. I know the folders/names etc are in good working order. Is there any way to recover these using TestDisk? How might I, if possible, make the $Extend folder show up in the partition contents?
Hidden File Structure: https://drive.google.com/file/d/1hUQ4ct ... sp=sharing
(While Recuva finds the folders there are many files that it cannot recover because the "file ame is too long" message. Other expensive recovery programs are able to recover these files without issue...)
Thanks for any help!
Peter
Sat May 22 16:48:26 2021
TestDisk 7.2-WIP, Data Recovery Utility, Novembre 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=5000981077504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1500301885440
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=5000981077504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1500301885440
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=483927261184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=26843545600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1500291039744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=3220755655168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=1780090833920
Disk /dev/sda - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - SAMSUNG MZVLB512HAJQ-000L2, S/N:0025_388B_7100_07A7., FW:2L1QEXA7
Disk /dev/sdb - 5000 GB / 4657 GiB - CHS 608001 255 63, sector size=512 - Seagate Expansion, S/N:NAAYKR7H, FW:0712
Disk /dev/sdc - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - Samsung G3 Station, S/N:801130168383
Disk /dev/sdc - 1500 GB / 1397 GiB - Samsung G3 Station
NTFS at 1/1/1
1 E extended LBA 1 0 1 182400 254 63 2930256000
5 L HPFS - NTFS 1 1 1 182400 254 63 2930255937 [Samsung]
NTFS, blocksize=4096, 1500 GB / 1397 GiB
Analyse Disk /dev/sdc - 1500 GB / 1397 GiB - CHS 182401 255 63
NTFS at 1/1/1
NTFS at 1/1/1
filesystem size 2930255937
mft_lcn 3
mftmirr_lcn 183140996
file_pread(6,2,buffer,2930278399(182401/100/35)) lseek err Invalid argument
file_pread(6,1,buffer,2930278399(182401/100/35)) lseek err Invalid argument
file_pread(6,2,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(6,1,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(6,8,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(6,1,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(6,8,buffer,2930277376(182401/84/20)) lseek err Invalid argument
file_pread(6,8,buffer,2930277504(182401/86/22)) lseek err Invalid argument
file_pread(6,8,buffer,2930277632(182401/88/24)) lseek err Invalid argument
file_pread(6,8,buffer,2930277760(182401/90/26)) lseek err Invalid argument
file_pread(6,8,buffer,2930277888(182401/92/28)) lseek err Invalid argument
file_pread(6,8,buffer,2930278016(182401/94/30)) lseek err Invalid argument
file_pread(6,8,buffer,2930278144(182401/96/32)) lseek err Invalid argument
file_pread(6,8,buffer,2930278272(182401/98/34)) lseek err Invalid argument
file_pread(6,7,buffer,2930278401(182401/100/37)) lseek err Invalid argument
file_pread(6,8,buffer,2930278408(182401/100/44)) lseek err Invalid argument
file_pread(6,3,buffer,2930278416(182401/100/52)) lseek err Invalid argument
file_pread(6,3,buffer,2930278463(182401/101/36)) lseek err Invalid argument
file_pread(6,8,buffer,2930278479(182401/101/52)) lseek err Invalid argument
file_pread(6,11,buffer,2930278526(182401/102/36)) lseek err Invalid argument
file_pread(6,2,buffer,2930280448(182401/133/5)) lseek err Invalid argument
NTFS Volume is dirty.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 22-May-2021 16:17 .
5 dr-xr-xr-x 0 0 0 22-May-2021 16:17 ..
1477 dr-xr-xr-x 0 0 0 10-Oct-2020 15:27 $RECYCLE.BIN
32 dr-xr-xr-x 0 0 0 11-May-2021 08:27 New folder
24907 dr-xr-xr-x 0 0 0 19-Oct-2010 10:46 RECYCLER
26004 dr-xr-xr-x 0 0 0 13-Oct-2010 10:23 Recycled
34 dr-xr-xr-x 0 0 0 6-Sep-2010 10:43 SamsungSoftware
27 dr-xr-xr-x 0 0 0 10-Aug-2018 17:42 System Volume Information
29 dr-xr-xr-x 0 0 0 6-Sep-2010 10:43 VProRecovery
122 -r--r--r-- 0 0 4268032 1-Apr-2010 18:04 AppInst.exe
123 -r--r--r-- 0 0 88 30-Dec-2009 23:35 Autorun.inf
1523 -r--r--r-- 0 0 2770568 10-Oct-2020 15:53 HFExt.exe
1523 -r--r--r-- 0 0 126 10-Oct-2020 15:53 HFExt.exe:Zone.Identifier
1524 -r--r--r-- 0 0 2770568 9-Sep-2020 06:36 test.exe
1524 -r--r--r-- 0 0 126 9-Sep-2020 06:36 test.exe:Zone.Identifier
add_ext_part_i386: max
add_ext_part_i386: min
Hidden Folder Not Found in Partition
Re: Hidden Folder Not Found in Partition
Yes, if you use your proprietary "hide-folders" software to convert the on-disk folder structures back to standard NTFS.201pilot wrote: 22 May 2021, 08:32 Hello,
From the FAQ of your software product:
I doubt that. If there are no changes in the file system it will be sufficient to connect a drive with hidden folders to a machine where the filter driver is not installed.Does Hide Folders change file system?
Not at all.
Thank you for your message!
I cannot use the FSPro software to unhide the folder because windows cannot access the disk! If only it could be so easy. All Windows tells me to do is format the drive!
P
P
Using undocumented proprietary stuff as p.e. Microsoft Storage Spaces or your software will always result in data loss when not performing backups.
You would need to ask the author of your software for help because he has his documentation on file.
Apart from that your secret other recovery software is able to do the recovery job, you said.
