photorec looping/stuck
akhi
#1 Post by akhi »
Hello;
### Linux, Ubuntu 18
Issue; Photorec keeps looping around the same sector.
I've read other topics and followed with the answer: viewtopic.php?p=26455#p26455
Deleted every recovered sector and left the latest line. In my case ;
cat photorec.ses
#1621924409
/dev/sdb partition_gpt,255,blocksize,1024,fileopt,options,paranoid,keep_corrupted_file_no,mode_ext2,wholespace,search,status=ext2_on,1705935920,inter
1706005926-7814037167
But keeps looping . Taking a look at the "top/iotop" I can see it's writing data of 4k , but actually nothing is written, and just keeps looping.
Can I jump to a bit far ahead sector? In case of yes, are there specific numbers that I should keep in mind while trying? I kept a backup copy of photorec.ses with all recovered sectors just in case.
Thanks for the support.
Re: photorec looping/stuck
Which version do you use?
akhi
#3 Post by akhi »
recuperation wrote: 25 May 2021, 13:12 Which version do you use?
Version 7.0
The output is stuck ( it doesn't even try sectors or anything ) . Restarted multiple times, this is output of a just made restart
Disk /dev/sdb - 4000 GB / 3726 GiB (RO)
     Unknown                        0 7814037167 7814037168 [Whole disk]
Pass 0 - Reading sector 1705996288/7814037168, 0 files found
Elapsed time 0h02m07s - Estimated time to completion 0h07m34
Use 7.2 WIP.
