Data Recovery from an External HDD
Xplozv123
#1 Post by Xplozv123 »
Hope you are doing great.
I am having a problem recovering data from my external HDD. When I connect it to my laptop, its shows " Need to format in order to use it". It has 2 partitions and both of them contain very very important data. It shows as a RAW disk in disk partition in " Disk Management" utility of windows.
Tried following the steps shared in the .pdf as well as from the Wiki page of TestDisk.
I am confused as to how should I proceed or Am i doing something wrong in here.
Below is the Log -
Please help me.
Eagerly waiting for an early reply.
Thank you in advance.
Mon Jun 21 02:12:05 2021
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000204884992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=248752314880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=53687091200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=429496729600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=87505764352
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=251832303616
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=734003200000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=429496729600
Disk \\.\PhysicalDrive0 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - CT250MX500SSD4, S/N:1918E1FF0B43, FW:M3CR023
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 860 QVO 1TB, S/N:S4PGNF0M433233H, FW:RVQ02B6Q
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Mass Storage Device, S/N:116AC2101219
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - Mass Storage Device
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525165 (expected 1953525165)
hdr_lba_start=34
hdr_lba_end=1953525132
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Reserved 1026048 1288191 262144 [Microsoft reserved partition]
3 P MS Data 1288192 493148159 491859968 [Basic data partition]
5 P MS Data 494886912 1928486911 1433600000 [Basic data partition]
1 P EFI System 2048 1026047 1024000 [EFI system partition]
4 P Windows Recovery Env 493150208 494886911 1736704
6 P Windows Recovery Env 1928488960 1929410559 921600
7 P Windows Recovery Env 1929410560 1953523711 24113152
FAT32 at 0/32/33
FAT1 : 6206-7198
FAT2 : 7199-8191
Data : 8192-1023999
sectors : 1024000
cluster_size : 8
no_of_cluster : 126976 (2 - 126977)
fat_length 993 calculated 993
FAT32 at 0/32/33
FAT: cluster=2(0x2), pos=10240
EFI System 2048 1026047 1024000 [EFI System Partition] [ESP]
FAT32, blocksize=4096, 524 MB / 500 MiB
LVM magic value at 71/16/25
NTFS at 80/47/33
filesystem size 491859968
mftmirr_lcn 2
NTFS part_offset=659554816, part_size=251832303616, sector_size=512
NTFS at 80/47/33
mftmirr_lcn 2
MS Data 1288193 493148160 491859968 [New Volume]
NTFS, blocksize=4096, 251 GB / 234 GiB
NTFS at 30697/36/47
filesystem size 491861428
mftmirr_lcn 2
MS Data 1288192 493149619 491861428
NTFS found using backup sector, blocksize=4096, 251 GB / 234 GiB
NTFS at 30697/36/47
mftmirr_lcn 2
MS Data 493149619 985011046 491861428
NTFS at 120042/225/56
filesystem size 921600
mft_lcn 38400
mftmirr_lcn 2
MS Data 1927567361 1928488960 921600
NTFS found using backup sector, blocksize=4096, 471 MB / 450 MiB
mft_lcn 38400
mftmirr_lcn 2
MS Data 1928488960 1929410559 921600
NTFS, blocksize=4096, 471 MB / 450 MiB
P EFI System 2048 1026047 1024000 [EFI System Partition] [ESP]
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS Volume is dirty.
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
5 dr-xr-xr-x 0 0 0 10-Mar-2019 20:28 .
5 dr-xr-xr-x 0 0 0 10-Mar-2019 20:28 ..
NTFS filesystem needs to be repaired.
ntfs_dir: ntfs_inode_open failed
Invalid partition structure.
Re: Data Recovery from an External HDD
Xplozv123 wrote: 20 Jun 2021, 22:29 I am confused as to how should I proceed or Am i doing something wrong in here.
I can't see where you are.
Apart from that I see a lot of read/write errors in the log file.
You might need to duplicate the drive using ddrescue as described in the manual.
To get health information about your drive quickly, use
viewtopic.php?f=5&t=10910
and post the log file here.
Xplozv123
#3 Post by Xplozv123 »
Hi, recuperation
I did the procedure again. Now, according to LogFile and Photorec, I am able to confirm that the partitions holding my data are 3 and 5.
Could you please share how to recover data from these 2 partitions as they are denoted as MS Data ( Basic Data Partition)?
https://mega.nz/file/n9QWSB5B#dNdAyQnB7 ... SD5Oc4cVdk
Log
Mon Jun 21 13:22:03 2021
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
