Trying to recover an HFS+ partition that was accidentally formatted
yuanqi
#1 Post by yuanqi »
Old partition occupies the whole disk. There are a few VMware images, which accounts for the smaller partitions found on full scan. The files I am trying to recover are rather large video files. I have had some success with some of the files via Prosoft Data Rescue, but the rest are only partially recovered (I'm assuming the software is not able to deal with fragmentation. https://www.dropbox.com/s/8c2eta396xedk ... g.zip?dl=0
yuanqi
Re: Trying to recover an HFS+ partition that was accidentally formatted
#2 Post by yuanqi »
I'm posting the beginning of the log in case people are having trouble with the link.
Mon Mar 22 19:05:42 2021
TestDisk 7.2-WIP, Data Recovery Utility, February 2021
OS: Darwin, kernel 18.7.0 (Darwin Kernel Version 18.7.0: Tue Jan 12 22:04:47 PST 2021; root:xnu-4903.278.56~1/RELEASE_X86_64) x86_64
Compiler: GCC 4.0
Compilation date: 2021-02-28T12:00:35
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 5.4
Disk /dev/disk0 - 1050 GB / 978 GiB - 2051200368 sectors (RO), sector size=512
Disk /dev/disk2 - 4000 GB / 3726 GiB - 976754645 sectors, sector size=4096
Disk /dev/rdisk0 - 1050 GB / 978 GiB - 2051200368 sectors (RO), sector size=512
Disk /dev/rdisk1 - 1050 GB / 977 GiB - 256348836 sectors (RO), sector size=4096
Disk /dev/rdisk2 - 4000 GB / 3726 GiB - 976754645 sectors, sector size=4096
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976754644 (expected 976754644)
hdr_lba_start=6
hdr_lba_end=976754639
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P Mac HFS                        1  976754644  976754644
HFS_HFSP_boot_sector
Volume header
Bad
Backup volume header
Bad
Sectors are identical.
Analyse Disk /dev/disk2 - 4000 GB / 3726 GiB - 976754645 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_start=6
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
No HFS or HFS+ structure
FAT32 at 6/0/1
FAT1 : 32-106
FAT2 : 107-181
start_rootdir : 182 root cluster : 2
Data : 182-76799
sectors : 76800
cluster_size : 1
no_of_cluster : 76618 (2 - 76619)
fat_length 75 calculated 75
sect/track 32 (FAT) != 1 (HD)
FAT32 at 6/0/1
     EFI System                     6      76805      76800 [EFI System Partition] [EFI]
     FAT32, blocksize=4096, 314 MB / 300 MiB
HFS+ magic value at 91713/0/1
part_size 976519142
     Mac HFS                    91713  976610854  976519142
     HFS+ blocksize=8192, 3999 GB / 3725 GiB
   P EFI System                     6      76805      76800 [EFI System Partition] [EFI]
   P Mac HFS                    91713  976610854  976519142
 1 P EFI System                     6      76805      76800 [EFI System Partition] [EFI]
 2 P Mac HFS                    91713  976610854  976519142
FAT32 at 6/0/1
FAT1 : 32-106
FAT2 : 107-181
Data : 182-76799
sectors : 76800
cluster_size : 1
FAT32 at 6/0/1
FAT32 at 12/0/1
FAT1 : 32-106
FAT2 : 107-181
Data : 182-76799
sectors : 76800
cluster_size : 1
FAT differs, FAT sectors=64-75/75
FAT32 at 12/0/1
     EFI System                    12      76811      76800 [EFI System Partition] [EFI]
part_size 976519142
HFS+ magic value at 91723/0/1
part_size 976519142
     Mac HFS                    91723  976610864  976519142
HFS+ magic value at 91733/0/1
part_size 976519142
     Mac HFS                    91733  976610874  976519142
HFS+ magic value at 91743/0/1
part_size 976519142
     Mac HFS                    91743  976610884  976519142
HFS+ magic value at 91753/0/1
part_size 976519142
     Mac HFS                    91753  976610894  976519142
#3 Post by recuperation »
Search for posts on the same topic before posting a
new question.
yuanqi
#4 Post by yuanqi »
Can I confirm that testdisk is not able to recover HFS+ partition if the backup volume header is also bad, and I would need to try photorec instead?
#5 Post by recuperation »
Your initial posting is incomprehensible. There is no logical connection between your posting title and the content.
As stated on the top page of https://www.cgsecurity.org/
Testdisk can find different types of lost partitions listed in this sentence:
If you have lost partition or strange problem with your hard disk partitions, run TestDisk to recover your data. TestDisk detects numerous filesystem including NTFS, FAT12, FAT16, FAT32, exFAT, ext2, ext3, ext4, btrfs, BeFS, CramFS, HFS, JFS, Linux Raid, Linux Swap, LVM, LVM2, NSS, ReiserFS, UFS, XFS.
Unfortunately Testdisk can only do a few things inside a small selection of partition types listed above.
TestDisk can also undelete files from FAT, NTFS, exFAT and ext2 filesystem.
Testdisk can do some very basic repairs.
You formated your HFS(+) partition. Formating does not mean loosing the partition. It affects the content of the partition.
Therefore you don't have a lost HFS+ partition. The partition is there but you overwrote some content.
Yes, only Photorec would help you now with your formated HFS+ partition.
