Partition Error Unallocated in External HD
grebnavi
#1 Post by grebnavi »
Helo! I am trying to recover data from my Seagate External Hard Drive.
These are important files for me. Family photos and work files. The HD was a few days without me using. Was planning to back up to cloud storage. But I can't access HD content anymore.
In Windows Disk Manager, it shows it as RAW.
I followed the TestDisk step by step and when I reached the step of locating the partitions, the answer is “Partition Read Error”.
Even when I choose to use the Deep Search option, the result is still “No Partition Found or Selected for Recovery.”
I ask: what step should I follow now to try to recover this HD?
I've already used chkdsk commands and it doesn't work since the disk is RAW.
I thank the attention.
Imagem 01
*I take this opportunity and ask: would this CHS information be correct?
Imagem 02
Imagem 03
Re: Partition Error Unallocated in External HD
Your disk has unreadable sectors - maybe even a bigger dammage.
Given your valuable data you might consider contacting a professional recovery service.
For a quick diagnosis you can extract SMART parameters as described here and post them in the forum:
viewtopic.php?f=5&t=10910
Depending on the outcome you could try to duplicate the drive using ddrescue as described in the manual.
