NTFS partition: all files accessible but partition not accessible and overlaps another partition i don't need
intraz
#1 Post by intraz »
Hi all,
By mistake, I deleted all partitions on my data disk (10TB WD with 2TB of actual data) during Windows installation.
Realised it immediately after the fact and made sure to have nothing access it so data is not compromised.
Used TestDisk from a live USB and then from Windows 10 after it was installed (on a different disk).
I recreated the boot sector and MBR.
I tried different other things but couldn't make the partition accessible in Windows (I was not really sure about all steps).
The issue seems to be overlap with another partition.
See attached log file of several attempts.
All my files in the one NTFS partition I care about are there and seem completely intact.
I copied them to a different disk for backup.
I could have called it end of story here but I would really like to simply make the partition accessible as copying all those files takes a long long time.
I feel like I am missing a trivial step to make it work.
I thought of marking the other partition as Deleted and then Write but was afraid of consequences due to overlap (even though I guess the writing is only done into the partition table).
TLDR:
NTFS partition not accessible in Windows
But all files accessible in TestDisk.
Might be due to overlapping partition.
Would like to make the NTFS partition accessible.
Do not care about anything else on the drive.
Would gladly provide any other relevant info.
Would appreciate any ideas or further steps.
Thanks a lot and in advance,
Eyal
Not sure how to attach a file here so pasting the log file below:
Wed Jul  7 03:14:26 2021
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=10000831348736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1999741443072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2199023255040
Disk \\.\PhysicalDrive0 - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - WDC WD102KRYZ-01A5AB0, S/N:VCG5BGGN, FW:01.01H01
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung SSD 980 PRO 2TB, S/N:0025_38B1_1150_65DC., FW:3B2QGXA7
Disk \\.\PhysicalDrive0 - 10000 GB / 9314 GiB - WDC WD102KRYZ-01A5AB0
Analyse Disk \\.\PhysicalDrive0 - 10000 GB / 9314 GiB - CHS 1215865 255 63
NTFS at 2/10/9
 1 E extended LBA             1 232 40 267351  66 42 4294967295
 5 L HPFS - NTFS              2  10  9 267351  99 11 4294967295 [Data]
NTFS at 2/10/9
filesystem size           4294967295
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 2199 GB / 2047 GiB
file_win32_pread(516,2,buffer,19532873727(1215865/39/46)) read err: read after end of file
   * HPFS - NTFS              2  10  9 267351  99 12 4294967296 [Data]
     NTFS, blocksize=4096, 2199 GB / 2048 GiB
 1 * HPFS - NTFS              2  10  9 267351  99 12 4294967296 [Data]
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
BAD_RS LBA=8621588288 2920290
     FAT16 <32M           536669  12 48 581885  34 10  726396389
   P FAT16 <32M           536669  12 48 581885  34 10  726396389
add_ext_part_i386: max
add_ext_part_i386: min
 1 E extended LBA             1 232 40 267351  99 12 4294969344
 2 P FAT16 <32M           536669  12 48 581885  34 10  726396389
 5 L HPFS - NTFS              2  10  9 267351  99 12 4294967296 [Data]
write!
write_all_log_i386: CHS: 1/232/40,lba=30720
Wed Jul  7 19:23:16 2021
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=371914951168
test_FAT()
 2 P FAT16 <32M           267349  89  4 312565 110 29  726396389
sector_size  60785
cluster_size 182
reserved     3898
fats         69
dir_entries  10781
sectors      47740
media        C5
fat_length   52122
secs_track   58469
heads        41848
hidden       307546634
total_sect   1029188780
NTFS at 2/10/9
Invalid FAT boot sector
NTFS at 2/10/9
mftmirr_lcn               2
file_win32_pread(520,2,buffer,19532873727(1215865/39/46)) read err: read after end of file
test_FAT()
sector_size  60785
cluster_size 182
reserved     3898
fats         69
dir_entries  10781
sectors      47740
media        C5
fat_length   52122
secs_track   58469
heads        41848
hidden       307546634
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
NTFS filesystem needs to be repaired.
NTFS at 2/10/9
mftmirr_lcn               2
 1 P HPFS - NTFS              2  10  9 267351  99 12 4294967296 [Data]
write!
Wed Jul  7 19:31:32 2021
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
NTFS at 2/10/9
 1 P HPFS - NTFS              2  10  9 267351  99 11 4294967295 [Data]
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
file_win32_pread(524,2,buffer,19532873727(1215865/39/46)) read err: read after end of file
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
Wed Jul  7 21:36:28 2021
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
NTFS at 2/10/9
ntfs_boot_sector
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
NTFS at 2/10/9
mftmirr_lcn               2
Wed Jul  7 22:10:32 2021
NTFS at 2/10/9
Backup partition structure
partition_save
NTFS at 2/10/9
mftmirr_lcn               2
file_win32_pread(540,2,buffer,19532873727(1215865/39/46)) read err: read after end of file
NTFS at 2/10/9
mftmirr_lcn               2
Re: NTFS partition: all files accessible but partition not accessible and overlaps another partition i don't need
intraz wrote: 08 Jul 2021, 17:27 TLDR:
intraz wrote: 08 Jul 2021, 17:27 I thought of marking the other partition as Deleted and then Write but was afraid of consequences due to overlap (even though I guess the writing is only done into the partition table).
When using GPT as partition table, you need to mark the partition to be recovered as primary and any overlapping ones as deleted and write.
intraz
#3 Post by intraz »
recuperation wrote: 09 Jul 2021, 08:59 intraz wrote: ↑Yesterday, 19:27
TLDR:
It's an acronym for "Too Long. Didn't read".
I meant this as a summary of the situation and my request.
Thanks a lot.
I will try and update.
intraz
#4 Post by intraz »
Hi recuperation,
I wanted to try your suggestion but the next quick search gave a different partition structure.
I decided to run a deep search and got the following log file:
Sat Jul 10 02:55:28 2021
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1919725657088
NTFS at 2/10/9
NTFS at 2/10/9
mftmirr_lcn               2
NTFS at 2/10/9
mftmirr_lcn               2
BAD_RS LBA=4443370073 500453
     FAT32 LBA            276586 253 45 341850  17 56 1048451304
NTFS at 1215864/229/45
filesystem size           19532836864
mftmirr_lcn               2
     HPFS - NTFS              2  10  9 1215864 229 45 19532836864 [Data]
     NTFS found using backup sector, blocksize=4096, 10000 GB / 9313 GiB
My original NTFS partition was on the entire disk so it seems to match the second NTFS partition in the results.
The size of the first NTFS partition is 2GB when the size of all the files I copied off the HDD using TestDisk is around 3.4GB.
So it looks like I should delete the first NTFS partition and keep the second one (as Primary as you suggested before). Side note: I am able to view all files in both of them.
Also, I am not sure what to do with the FAT partitions.
Would appreciate your input on both the FAT and NTFS partitions.
Thanks!
Eyal
#5 Post by recuperation »
You did not unterstand when i wrote "When using a GPT table".
As the log states a sector size of 512, you should select GPT as partition table style.
With a sector size of 512 byte only 2TB of your drive can be addressed and used.
Some external drives with a native sector size of 512 come with an additional interface electronics that seem to contain a converter showing a sector size of 4096 byte. Only in a such a case using the old MBR-style partition table is possible.
If you bought a naked drive without enclosure name the manufacturer and product so that I can see which sector size your drive uses or shows externally.
That determines the right partition table choice.
Please provide the information requested and rerun Testdisk again creating a log based on the selection of GPT.
intraz
#6 Post by intraz »
Thank you for the clarification.
My drive is a 10TB WD Gold Enterprise Class SATA Hard Drive (https://shop.westerndigital.com/product ... #WD102KRYZ).
I will rerun TestDisk with GPT selected as the partition table style and update here with the new log file.
intraz
#7 Post by intraz »
Quick update,
I started a new quick search after choosing GPT partition table type.
It's running extremely slowly. 3% in 7 hours since I started.
At this rate it will take about a week to finish. Is this normal?
Current log:
Tue Jul 13 00:06:12 2021
Partition table type: EFI GPT
New options :
 Dump : No
 Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=19532873727 (expected 19532873727)
hdr_lba_start=34
hdr_lba_end=19532873694
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=19532873727
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_table=19532873695
hdr_entries=128
hdr_entsz=128
Trying alternate GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_start=34
hdr_entries=128
hdr_entsz=128
Ongoing test info:
Analyse cylinder 309269/1215864: 25%
  MS Data                    32768 4295000062 4294967295 [Data]
  Linux filesys. data   4704189757 4704528073     338316 [~W6~D^OM-,~Wj>/M-8^Ya$M-%']
