i want to use my partition again
CASC2019
#1 Post by CASC2019 »
Good afternoon
I come with a problem that I will try to summarize.
A virus slowed down my partition called "Data" on June,18. After trying to delete it, I decided to format the partition. And I chose deep formatting but it never finished and stopped at 62%, after a week.
When I restarted the computer, it appeared to me as a RAW disk. And it couldn't be formatted with CMD because it was a RAW disk.
So I decided to use TESTDISK and it showed me 4 options and within "Deeper Search" many more with "No files".
However, I opted for the one "green" with "1-1" in "Start" because is a "Logical Partition" and now the partition appears very divided.
Did I choose the correct partition? Is it possible to put everything together to format it?
Re: i want to use my partition again
What do want to do exactly?
Formating does not recover but destroys possibly recoverable content.
CASC2019
#3 Post by CASC2019 »
recuperation wrote: 13 Jul 2021, 23:51 What do want to do exactly?
I want to use that partition again with the letter D and see it in "This PC".
Testdisk is the wrong program when you want to delete everything.
