Drive was initially NTFS on a Win XP machine.
I hooked it up to another PC in an attempt to recover what was on it. (XP as well)
Windows does see the drive and assigned it to E:\
However I can't access it.
Using test disk I was able to see the drive just fine but it seems that the filesystem is damaged.
Is there anything I can do to regain access to that drive?
I apologize for my noobish questions.
I have attached a step-by-step print screen of what I have tried so far.
Step 1
Step 2
Step 3
Step 4
Step 5
So I'm a bit stuck and have no clue what I should do next.
If I hit P I get an error message saying "Can't open filesystem. Filesystem seems damaged"
If I just hit enter it returns to a screen where I can see the partition and have 3 options.
[Quit] [Deeper Search] [Write]
I wasn't sure if I need to write the partition structure to disk and wanted to ask before I go and do anything bananas.
Thanks for your time in reading this and maybe one of you guys can steer me in the right direction.
