External turned dark (Raw and missing partition )
prosaic
#1 Post by prosaic »
Hi everyone,
I've run a test on an external 1tb, chkdsk says its a RAW drive. TestDisk with quick and deeper came up with no results.
This is chat log:
Tue Aug 31 00:07:08 2021
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=217281724416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\T:)=262144000000
Disk \\.\PhysicalDrive0 - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - CT480BX500SSD1, S/N:2015E3F60E06, FW:M6CR022
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - PHD 3.0 Silicon-Power, S/N:FE10#902001033420041
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - PHD 3.0 Silicon-Power
Analyse Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63
file_win32_pread(612,1,buffer,2050(0/32/35)) read err: read after end of file
Invalid FAT boot sector
 1 * FAT32 LBA                0  32 33 121601  25 24 1953519616
file_win32_pread(612,16,buffer,2080(0/33/2)) read err: read after end of file
file_win32_pread(612,1,buffer,2080(0/33/2)) read err: read after end of file
file_win32_pread(612,2,buffer,2082(0/33/4)) read err: read after end of file
file_win32_pread(612,16,buffer,2048(0/32/33)) read err: read after end of file
file_win32_pread(612,1,buffer,2048(0/32/33)) read err: read after end of file
file_win32_pread(612,16,buffer,479232(29/211/55)) read err: read after end of file
file_win32_pread(612,1,buffer,479232(29/211/55)) read err: read after end of file
file_win32_pread(612,1,buffer,479233(29/211/56)) read err: read after end of file
file_win32_pread(612,14,buffer,479234(29/211/57)) read err: read after end of file
file_win32_pread(612,3,buffer,479248(29/212/8)) read err: read after end of file
file_win32_pread(612,16,buffer,481280(29/244/24)) read err: read after end of file
file_win32_pread(612,1,buffer,481280(29/244/24)) read err: read after end of file
file_win32_pread(612,1,buffer,481281(29/244/25)) read err: read after end of file
file_win32_pread(612,14,buffer,481282(29/244/26)) read err: read after end of file
file_win32_pread(612,3,buffer,481296(29/244/40)) read err: read after end of file
file_win32_pread(612,3,buffer,481343(29/245/24)) read err: read after end of file
file_win32_pread(612,8,buffer,481359(29/245/40)) read err: read after end of file
file_win32_pread(612,11,buffer,481406(29/246/24)) read err: read after end of file
file_win32_pread(612,16,buffer,2047(0/32/32)) read err: read after end of file
file_win32_pread(612,15,buffer,2049(0/32/34)) read err: read after end of file
file_win32_pread(612,1,buffer,479231(29/211/54)) read err: read after end of file
file_win32_pread(612,1,buffer,481279(29/244/23)) read err: read after end of file
interface_load
Any assistance would be appreciated - trying to recover the partition or slowly take some important files.
Thanks!
EDIT: I'm trying to rebuild the boot sector with "RebuildBS" - Status: Searching for FAT Table 6%. (Stuck at 6 for awhile now)
Re: External turned dark (Raw and missing partition )
What is "external 1TB", please?!
prosaic
#3 Post by prosaic »
External 1TB is:
Currently picked up as FAT32 / with a table of "Intel" detected.
Snapshot of it with crystaldiskinfo:
Your drive is about to die already having 280 pending sectors.
Duplicate it as described in the manual.
Run Photorec and/or any other commercial recovery software solution.
prosaic
#5 Post by prosaic »
"Duplicate it as described in the manual."
I don't have a manual I'm afraid.
Would something like DDresuce work, running it off a LINUX distro via usb to clone the RAW Hardrive?
I've run Photorec previously but the filenames are not restored, and wondering if this hard drive will not recover its file structure??
Or is Photorec the only option?
Thanks!
#6 Post by recuperation »
1. Not two seconds left over for a google search?
2. Never looked into the unpacked downloaded Testdisk archive?
3. Did you ever notice that this forum is a subdomain of cgsecurity.org? Have you ever looked there?
Maybe I expect too much from users of this forum.
Now, please enter the stroller and let me drive you around:
1. Use Google to locate the manual.
2. The manual comes with the Testdisk download. In today's world software typically comes with digital manuals and not printed ones. So does Testdisk.
3. cgsecurity.org contains lots of information worth reading.
