Hi
I accidentally delete alot of .zip files. I tried to find them and I did, but when I want to recover them. They recovered but not the same size of the that I remember. One of the files was about 4GB and when I recover it the size of the .zip shows about 1.8Mb. Please help.
Recovering .zip files
Re: Recovering .zip files
It won't be wrong if you named the program you used.
Did you use compression when creating the zip files you deleted?
I compressed some images and videos using my phone(without any program); I moved them to my PC. And as I said before, I delete them and when I tried testdisk program to recover them; the program worked perfectly fine except the wrong size of files.
What is the copy target file system?
