"Support for this filesystem hasn't been implemented"
camus
#1 Post by camus »
I have this drive: WD 3TB WD30EFRX
Ii will not show up on any file manager on any OS.
I'm trying to use testdisk to determine why, or more important, wipe it clean.
I have done an initial scan and now, two days later doing a DeeperScan.
The results of the initial scan found three partitions:
>P Linux filesys. data         2046    4982397    4980352 [1.42.6-5644]
 P Linux Swap               4982520    4982535         16
 P Linux Raid               9453280 5860324199 5850870920 [DiskStation:2]
On the first partition, I get:
And on the second, Linux Raid partition, I get:
Support for this filesystem hasn't been implemented.
when I try to list the files in the found partitions.
Presently, I'm doing a DeepScan. Here is what the current scan results look like:
Disk /dev/sdf - 3000 GB / 2794 GiB - CHS 2861588 64 32
Analyse cylinder  6816/2861587: 00%
root@zeon1:/home/zeon# 8 (lba=7322235)
  Linux filesys. data      2128400    7108751    4980352 [1.42.6-5644]
  Linux filesys. data      2128552    7108903    4980352 [1.42.6-5644]
  Linux filesys. data      2128624    7108975    4980352 [1.42.6-5644]
  Linux filesys. data      2128856    7109207    4980352 [1.42.6-5644]
  Linux filesys. data      2128912    7109263    4980352 [1.42.6-5644]
  Linux filesys. data      2129000    7109351    4980352 [1.42.6-5644]
  Linux filesys. data      2129136    7109487    4980352 [1.42.6-5644]
  Linux filesys. data      2129240    7109591    4980352 [1.42.6-5644]
  Linux filesys. data      2129456    7109807    4980352 [1.42.6-5644]
  Linux filesys. data      2129536    7109887    4980352 [1.42.6-5644]
  Linux filesys. data      2129712    7110063    4980352 [1.42.6-5644]
  Linux filesys. data      2129752    7110103    4980352 [1.42.6-5644]
  Linux filesys. data      2129816    7110167    4980352 [1.42.6-5644]
Questions:
what should I do when the can completes?
since it says there is no support, should I continue
how can I simply completely wipe the drive, which is really what I want done. Don't need to recover data.
Thank you very much for your considered response.
Camus
Re: "Support for this filesystem hasn't been implemented"
Please consult any search engine or another forum how to erase a drive.
camus
#3 Post by camus »
recuperation wrote: 13 Sep 2021, 21:36 Please consult any search engine or another forum how to erase a drive.
Thank you for the insight, but how to erase the drive is among three questions asked. Perhaps you would be so kind as to, if you can, please help answer the other two questions.
Thanks a lot.
