Newbie - Please help, my data partition is raw :-)
Softwoolf
#1 Post by Softwoolf »
Dear All,
I need help - I have an adaptec raid controller with different arrays on it, all except one running fine. The problem is one faulty drive on one of the arrays, which happened suddenly - the drive is suddenly listed as "raw" in windows 10 and cannot be accessed.
Here we go:
https://www.cgsecurity.org TestDisk is free software, and
comes with ABSOLUTELY NO WARRANTY. Select a media (use Arrow keys, then press Enter):
Disk /dev/sda - 119 GB / 111 GiB - Adaptec Array
Disk /dev/sdb - 5991 GB / 5579 GiB - Adaptec Array
Disk /dev/sdc - 5996 GB / 5584 GiB - Adaptec Array
Disk /dev/sdd - 27 TB / 25 TiB - Adaptec Array -> this is the one with problems (I use EFI_GPT] to display th
Disk /dev/sde - 256 GB / 238 GiB - ATA SanDisk SDSSDP25
Disk /dev/sdf - 1000 GB / 931 GiB - NVMe Samsung SSD 970
Analyze gives me the following information:
Disk /dev/sdd - 27 TB / 25 TiB - CHS 3403871 255 63
Current partition structure: Partition Start End Size in sectors No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker
2 P MS Data 264192 17888805957 17888541766 [Basic data partition] No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker
3 P MS Data 17893405845 46871344276 28977938432 [Basic data partition]
Partition 3 works just fine.
Partition 2 is the one with the problem - and has the eroror message "No FAT, NTFS...marker".
I have not enough free space left in the system to backup the appr. 8.5TB - so can someone help me how to proceed without doing additional damage... ???
How to tell the partition its NTFS ?
Please help :-)
Softwoolf
Re: Newbie - Please help, my data partition is raw :-)
What is the exact configuration / type of array behind the label "drive sdd" (Adaptec array)?
Softwoolf
#3 Post by Softwoolf »
it is a RAID6
Please post the Testdisk log file. What does Testdisk says on the screen when searching for partitions?
Are you able to enter those using "list files"?
Softwoolf
#5 Post by Softwoolf »
TestDisk 7.1, Data Recovery Utility, July 2019 Christophe GRENIER <grenier@cgsecurity.org> https://www.cgsecurity.org
2 P MS Data 264192 17888805957 17888541766 [Basic data partition] Can't open filesystem. Filesystem seems damaged.
Doesn't sound good.... I added some disks to the controller to have enough diskspace for the testdisk image, problem is that I did a verify/fix on my adaptec raid controller and that hangs at 66% for 10h now.... and I know no way to abort this. Shutting down server didnt help and i cant find an option in the maxview storage manager. Even the commandline tool seems to have no option to abort the verify... when something hits the fan its either a small pretty bird or sh*t...
#6 Post by recuperation »
Rebuilding the array after including a healthy disk would be my first priority anyway.
Softwoolf
#7 Post by Softwoolf »
Yeah suddenly its progressing again ... 81 percent actually. I'm hoping the best and expecting the worst :-)
Softwoolf
#8 Post by Softwoolf »
Parttion image finally done - problem is that analyzing will need days - my output so far:
TestDisk 7.1, Data Recovery Utility, July 2019 Christophe GRENIER <grenier@cgsecurity.org> https://www.cgsecurity.org Disk z:\image.dd - 9158 GB / 8529 GiB - CHS 1113511 255 63 Analyse cylinder 46242/1113510: 04% Warning: number of sectors per track mismatches 2 (NTFS) != 63 (HD)
MS Data 33094899 33101072 6174 Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD) Warning: number of sectors per track mismatches 2 (NTFS) != 63 (HD)
MS Data 33101072 33107245 6174 [Boot] Warning: number of heads/cylinder mismatches 2 (FAT) != 255 (HD) Warning: number of sectors per track mismatches 18 (FAT) != 63 (HD)
EFI System 36538880 36541759 2880 [EFI System Partition] [EFISECTOR] Warning: number of heads/cylinder mismatches 2 (FAT) != 255 (HD) Warning: number of sectors per track mismatches 18 (FAT) != 63 (HD)
EFI System 38936672 38939551 2880 [EFI System Partition] [EFISECTOR] Warning: number of heads/cylinder mismatches 2 (FAT) != 255 (HD) Warning: number of sectors per track mismatches 18 (FAT) != 63 (HD)
EFI System 44035968 44038847 2880 [EFI System Partition] [EFISECTOR] Warning: number of heads/cylinder mismatches 2 (FAT) != 255 (HD) Warning: number of sectors per track mismatches 18 (FAT) != 63 (HD)
EFI System 44754176 44757055 2880 [EFI System Partition] [EFISECTOR] Mac HFS 50790826 617022123 566231298 Linux filesys. data 518253486 641932205 123678720
Linux filesys. data 701231510 701297045 65536
there seem to be two big partitions - but that cant be. I just backuped the faulty partition... ? Any idea ???
