Windows on my Laptop crashed during a Windows update when I accidentally did hard reboot and I was not able to recover the windows back. So I setup USB live boot Kubuntu to recover the Data.
It was almost in good shape before I ran the Testdisk, but I saw some bad sectors errors. So I tried to use testdisk to recover the bad Partition table.
But I didnt choose options properly to backup the log or Partition Table. So I ended up running it twice and overwriting the Partition Table. So as I read in another thread: that I should recover the testdisk.log file and recreate the partitions manually.
I tried to recover the backup file. I got one for my second run I think(by that time my partition table might be overwritten already). Could you please help me understand it, as it looks too big. If I am able to find my old partitions
I will try to recover the one for the First run soon. (I disregarded the warning that it showed, that I should append to log instead of overwriting, which I regret)
Basically I had one C drive drive and on D:, i.e a Data drive with Laptop.. There might have been some hidden partitions and a recovery partition.
Any Help will be greatly appreciated!!
PLEASE HELP! Revert changes from Testdisk
KanchiLaxi
Re: PLEASE HELP! Revert changes from Testdisk
This is the Second Log I recovered (Please help with the Partitions I should recover from this Log):
Tue Sep 21 15:37:17 2021
OS: Linux, kernel 5.11.0-16-generic (#17-Ubuntu SMP Wed Apr 14 20:12:43 UTC 2021) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.45.7, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
/dev/sda: size 250069680 sectors
/dev/sda: user_max 250069680 sectors
/dev/sda: native_max 250069680 sectors
/dev/sdb: size 250069680 sectors
/dev/sdb: user_max 250069680 sectors
/dev/sdb: native_max 250069680 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 1953525168 sectors
/dev/sdc: user_max 1953525168 sectors
/dev/sdc: native_max 1953525168 sectors
Warning: can't get size for Disk /dev/loop5 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - SanDisk SD6SF1M128G, S/N:133715400384, FW:X231200
Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - SanDisk SD6SF1M128G, S/N:133715400314, FW:X231200
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - HGST HTS721010A9E630, S/N:JG40006PGDZDLC, FW:JB0OA3B0
Disk /dev/sdd - 16 GB / 15 GiB - CHS 15418 64 32, sector size=512 - Kingston DataTraveler 2.0, FW:1.00
Disk /dev/loop0 - 2049 MB / 1954 MiB - 4003752 sectors (RO), sector size=512
Disk /dev/loop1 - 58 MB / 55 MiB - 113536 sectors (RO), sector size=512
Disk /dev/loop2 - 68 MB / 65 MiB - 133320 sectors (RO), sector size=512
Disk /dev/loop3 - 33 MB / 32 MiB - 66152 sectors (RO), sector size=512
Disk /dev/loop4 - 5758 KB / 5624 KiB - 11248 sectors (RO), sector size=512
Disk /dev/sdb - 128 GB / 119 GiB - SanDisk SD6SF1M128G
Partition table type: EFI GPT
Analyse Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63
Trying alternate GPT
NTFS at 1/101/13
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 16267 22440 6174
NTFS at 1/101/13
mft_lcn 2058
mftmirr_lcn 5162
MS Data 22440 28613 6174
NTFS at 15/171/61
filesystem size 496106628
mftmirr_lcn 2
NTFS part_offset=128925696, part_size=254006593536, sector_size=512
NTFS at 15/171/61
mftmirr_lcn 2
MS Data 251808 496358435 496106628
NTFS, blocksize=4096, 254 GB / 236 GiB
This partition ends after the disk limits. (start=251808, size=496106628, end=496358435, disk end=250069680)
NTFS at 38/78/40
filesystem size 1228800
mft_lcn 51200
mftmirr_lcn 2
NTFS part_offset=315096576, part_size=629145600, sector_size=512
NTFS at 38/78/40
mft_lcn 51200
mftmirr_lcn 2
MS Data 615423 1844222 1228800
NTFS, blocksize=4096, 629 MB / 600 MiB
LVM magic value at 233/232/22
LVM magic value at 233/232/47
LVM magic value at 233/232/52
LVM magic value at 233/232/62
LVM magic value at 233/233/1
LVM magic value at 233/233/4
LVM magic value at 233/233/7
LVM magic value at 233/233/10
LVM magic value at 233/233/16
LVM magic value at 233/233/19
LVM magic value at 233/233/22
LVM magic value at 233/233/28
LVM magic value at 233/233/31
LVM magic value at 233/233/34
LVM magic value at 233/233/37
LVM magic value at 233/233/40
LVM magic value at 233/233/43
LVM magic value at 233/233/46
LVM magic value at 233/233/55
LVM magic value at 233/233/58
LVM magic value at 233/233/61
LVM magic value at 233/234/1
LVM magic value at 233/234/7
LVM magic value at 233/234/13
LVM magic value at 233/234/19
LVM magic value at 233/234/22
LVM magic value at 233/234/25
LVM magic value at 233/234/28
LVM magic value at 233/234/31
LVM magic value at 233/234/34
LVM magic value at 233/234/37
LVM magic value at 233/234/40
LVM magic value at 233/234/43
LVM magic value at 233/234/46
LVM magic value at 233/234/49
LVM magic value at 233/234/52
LVM magic value at 233/234/55
LVM magic value at 233/234/61
LVM magic value at 233/235/1
LVM magic value at 233/235/4
LVM magic value at 233/235/7
LVM magic value at 233/235/10
LVM magic value at 233/235/13
LVM magic value at 233/235/16
LVM magic value at 233/235/19
LVM magic value at 233/235/22
LVM magic value at 233/235/25
LVM magic value at 233/235/28
LVM magic value at 233/235/31
LVM magic value at 233/235/34
LVM magic value at 233/235/37
LVM magic value at 233/235/40
LVM magic value at 233/235/43
LVM magic value at 233/235/46
LVM magic value at 233/235/52
LVM magic value at 233/235/55
LVM magic value at 233/235/61
LVM magic value at 233/236/4
LVM magic value at 233/236/7
LVM magic value at 233/236/10
LVM magic value at 233/236/13
LVM magic value at 233/236/19
LVM magic value at 233/236/22
LVM magic value at 233/236/25
LVM magic value at 233/236/28
LVM magic value at 233/236/31
LVM magic value at 233/236/34
LVM magic value at 233/236/37
cramfs Marker at 473/98/19
recover_cramfs
Linux filesys. data 7604937 8976920 1371983 [GW¹¤Ø«ÝнÍ(bždSÜ]
cramfs, 702 MB / 669 MiB
FAT12 at 873/84/32
check_FAT: Unusual media descriptor (0xf8!=0xf0)
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
no_of_cluster : 2586 (2 - 2587)
fat_length 8 calculated 8
FAT differs, FAT sectors=0-8/8
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 17 (FAT) != 63 (HD)
FAT12 at 873/84/32
MS Data 14030068 14050806 20739 [NO NAME]
FAT12 at 996/12/33
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT differs, FAT sectors=0-9/9
FAT12 at 996/12/33
MS Data 16001528 16004407 2880 [NO NAME]
NTFS at 1028/162/15
mft_lcn 2058
mftmirr_lcn 5162
MS Data 16518867 16525040 6174
NTFS at 1028/162/15
mft_lcn 2058
mftmirr_lcn 5162
MS Data 16525040 16531213 6174
LVM magic value at 1050/55/32
FAT12 at 1538/171/18
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 24718760 24721639 2880 [NO NAME]
FAT12 at 1916/146/31
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 30789768 30792647 2880 [NO NAME]
LVM magic value at 2406/182/33
LVM magic value at 3062/85/26
LVM magic value at 3635/136/24
LVM magic value at 3635/136/27
LVM magic value at 3635/136/30
LVM magic value at 3635/136/33
LVM magic value at 3635/136/36
LVM magic value at 3635/136/39
LVM magic value at 3635/136/42
LVM magic value at 3635/136/48
LVM magic value at 3635/136/54
LVM magic value at 3635/164/50
LVM magic value at 3635/164/53
LVM magic value at 3635/164/56
LVM magic value at 3635/164/59
LVM magic value at 3635/164/62
LVM magic value at 3635/165/5
LVM magic value at 3635/165/8
LVM magic value at 3635/165/11
LVM magic value at 3635/165/14
LVM magic value at 3635/165/17
LVM magic value at 3635/165/20
LVM magic value at 3635/165/23
LVM magic value at 3635/165/26
LVM magic value at 3635/165/32
LVM magic value at 3635/165/38
LVM magic value at 3635/165/41
LVM magic value at 3635/165/44
LVM magic value at 3635/165/47
LVM magic value at 3635/165/50
LVM magic value at 3635/165/53
LVM magic value at 3635/165/56
LVM magic value at 3635/165/59
LVM magic value at 3635/165/62
LVM magic value at 3635/166/5
LVM magic value at 3635/166/11
LVM magic value at 3635/166/14
LVM magic value at 3635/166/20
LVM magic value at 3635/166/23
LVM magic value at 3635/166/26
LVM magic value at 3635/166/29
LVM magic value at 3635/166/32
LVM magic value at 3635/166/35
LVM magic value at 3635/166/38
LVM magic value at 3635/166/41
LVM magic value at 3635/166/44
LVM magic value at 3635/166/47
LVM magic value at 3635/166/50
LVM magic value at 3635/166/53
LVM magic value at 3635/166/56
LVM magic value at 3635/166/59
LVM magic value at 3635/166/62
LVM magic value at 3635/167/2
LVM magic value at 3635/167/5
LVM magic value at 3635/167/8
LVM magic value at 3635/167/11
LVM magic value at 3635/167/14
LVM magic value at 3635/167/17
LVM magic value at 3635/167/20
LVM magic value at 3635/167/23
LVM magic value at 3635/167/26
LVM magic value at 3635/167/29
LVM magic value at 3635/167/32
LVM magic value at 3635/167/38
LVM magic value at 3635/167/44
LVM magic value at 3635/167/47
LVM magic value at 3635/167/53
LVM magic value at 3635/167/56
LVM magic value at 3635/167/59
LVM magic value at 3635/167/62
LVM magic value at 3635/168/8
LVM magic value at 3635/168/11
LVM magic value at 3635/168/14
LVM magic value at 3635/168/17
LVM magic value at 3635/168/20
LVM magic value at 3635/168/23
LVM magic value at 3635/168/32
LVM magic value at 3635/168/35
LVM magic value at 3635/168/38
LVM magic value at 3635/168/41
LVM magic value at 3635/168/44
LVM magic value at 3635/168/47
LVM magic value at 3635/168/50
NTFS at 3730/240/15
mft_lcn 2058
mftmirr_lcn 5162
MS Data 59931411 59937584 6174
NTFS at 3730/240/15
mft_lcn 2058
mftmirr_lcn 5162
MS Data 59937584 59943757 6174
LVM magic value at 4034/104/10
LVM magic value at 4334/205/12
LVM magic value at 4394/117/47
NTFS at 4448/75/12
mft_lcn 2058
mftmirr_lcn 5162
MS Data 71455683 71461856 6174
NTFS at 4448/75/12
mft_lcn 2058
mftmirr_lcn 5162
MS Data 71461856 71468029 6174
LVM magic value at 5146/1/55
LVM magic value at 5146/1/58
LVM magic value at 5146/2/4
LVM magic value at 5146/2/16
LVM magic value at 5146/2/22
LVM magic value at 5146/2/25
LVM magic value at 5146/2/31
LVM magic value at 5146/2/34
LVM magic value at 5146/2/37
LVM magic value at 5146/2/43
LVM magic value at 5146/2/49
LVM magic value at 5146/2/52
LVM magic value at 5146/2/55
LVM magic value at 5146/3/1
LVM magic value at 5146/3/4
LVM magic value at 5146/3/7
LVM magic value at 5146/3/10
LVM magic value at 5146/3/13
LVM magic value at 5146/3/16
LVM magic value at 5146/3/19
LVM magic value at 5146/3/22
LVM magic value at 5146/3/25
LVM magic value at 5146/3/28
LVM magic value at 5146/3/34
LVM magic value at 5146/3/37
LVM magic value at 5146/3/40
LVM magic value at 5146/3/43
LVM magic value at 5146/3/46
LVM magic value at 5146/3/49
LVM magic value at 5146/3/52
LVM magic value at 5146/3/55
LVM magic value at 5146/3/58
LVM magic value at 5146/3/61
LVM magic value at 5146/4/1
LVM magic value at 5146/4/4
LVM magic value at 5146/4/7
LVM magic value at 5146/4/10
LVM magic value at 5146/4/13
LVM magic value at 5146/4/16
LVM magic value at 5146/4/19
LVM magic value at 5146/4/25
LVM magic value at 5146/4/28
LVM magic value at 5146/4/31
LVM magic value at 5146/30/21
LVM magic value at 5146/30/30
LVM magic value at 5146/30/33
LVM magic value at 5146/30/39
LVM magic value at 5146/30/42
LVM magic value at 5146/30/45
LVM magic value at 5146/30/51
LVM magic value at 5146/30/54
LVM magic value at 5146/30/60
LVM magic value at 5146/31/3
LVM magic value at 5146/31/6
LVM magic value at 5146/31/9
LVM magic value at 5146/31/12
LVM magic value at 5146/31/21
LVM magic value at 5146/31/24
LVM magic value at 5146/31/27
LVM magic value at 5146/31/33
LVM magic value at 5146/31/36
LVM magic value at 5146/31/42
LVM magic value at 5146/31/63
LVM magic value at 5146/32/3
LVM magic value at 5146/32/6
LVM magic value at 5146/32/9
LVM magic value at 5146/32/12
LVM magic value at 5146/32/21
LVM magic value at 5146/32/27
LVM magic value at 5146/32/33
LVM magic value at 5146/32/39
LVM magic value at 5146/32/42
LVM magic value at 5146/32/45
LVM magic value at 5146/32/48
LVM magic value at 5146/32/54
LVM magic value at 5146/32/57
LVM magic value at 5146/32/60
LVM magic value at 5146/32/63
LVM magic value at 5146/33/3
LVM magic value at 5146/33/6
LVM magic value at 5146/33/9
LVM magic value at 5146/33/12
LVM magic value at 5146/33/15
LVM magic value at 5146/33/18
LVM magic value at 5146/33/21
LVM magic value at 5146/33/24
LVM magic value at 5146/33/30
LVM magic value at 5146/33/33
LVM magic value at 5146/33/36
LVM magic value at 5146/33/39
LVM magic value at 5146/33/42
LVM magic value at 5146/33/45
LVM magic value at 5146/33/48
LVM magic value at 5146/33/51
LVM magic value at 5146/33/54
LVM magic value at 5146/33/60
LVM magic value at 5146/33/63
LVM magic value at 5146/34/3
LVM magic value at 5146/34/6
recover_EXT2: s_block_group_nr=0/12, s_mnt_count=2/31, s_blocks_per_group=8192, s_inodes_per_group=1976
recover_EXT2: s_blocks_count 102400
recover_EXT2: part_size 204800
Filesystem created: Mon Jan 7 03:15:42 2013
Last mount time: Wed Jun 26 14:22:44 2013
Linux filesys. data 94340992 94545791 204800 [root]
ext4 blocksize=1024 Sparse_SB Recover, 104 MB / 100 MiB
LVM magic value at 5927/144/44
LVM magic value at 5927/144/50
LVM magic value at 5927/144/53
LVM magic value at 5927/144/56
LVM magic value at 5927/145/2
LVM magic value at 5927/145/5
LVM magic value at 5927/145/8
LVM magic value at 5927/145/11
LVM magic value at 5927/145/14
LVM magic value at 5927/145/17
LVM magic value at 5927/145/20
LVM magic value at 5927/145/23
LVM magic value at 5927/145/26
LVM magic value at 5927/145/29
LVM magic value at 5927/145/35
LVM magic value at 5927/145/38
LVM magic value at 5927/145/41
LVM magic value at 5927/145/44
LVM magic value at 5927/145/47
LVM magic value at 5927/145/50
LVM magic value at 5927/145/53
LVM magic value at 5927/145/56
LVM magic value at 5927/145/59
LVM magic value at 5927/145/62
LVM magic value at 5927/146/2
LVM magic value at 5927/146/5
LVM magic value at 5927/146/8
LVM magic value at 5927/146/11
LVM magic value at 5927/146/14
LVM magic value at 5927/146/17
LVM magic value at 5927/146/20
LVM magic value at 5927/146/26
LVM magic value at 5927/146/29
LVM magic value at 5927/146/32
LVM magic value at 5927/173/7
LVM magic value at 5927/173/10
LVM magic value at 5927/173/13
LVM magic value at 5927/173/22
LVM magic value at 5927/173/25
LVM magic value at 5927/173/28
LVM magic value at 5927/173/34
LVM magic value at 5927/173/37
LVM magic value at 5927/173/43
LVM magic value at 5927/174/1
LVM magic value at 5927/174/4
LVM magic value at 5927/174/7
LVM magic value at 5927/174/10
LVM magic value at 5927/174/13
LVM magic value at 5927/174/22
LVM magic value at 5927/174/28
LVM magic value at 5927/174/34
LVM magic value at 5927/174/40
LVM magic value at 5927/174/43
LVM magic value at 5927/174/46
LVM magic value at 5927/174/49
LVM magic value at 5927/174/55
LVM magic value at 5927/174/58
LVM magic value at 5927/174/61
LVM magic value at 5927/175/1
LVM magic value at 5927/175/4
LVM magic value at 5927/175/7
LVM magic value at 5927/175/10
LVM magic value at 5927/175/13
LVM magic value at 5927/175/16
LVM magic value at 5927/175/19
LVM magic value at 5927/175/22
LVM magic value at 5927/175/25
LVM magic value at 5927/175/31
LVM magic value at 5927/175/34
LVM magic value at 5927/175/37
LVM magic value at 5927/175/40
LVM magic value at 5927/175/43
LVM magic value at 5927/175/46
LVM magic value at 5927/175/49
LVM magic value at 5927/175/52
LVM magic value at 5927/175/55
LVM magic value at 5927/175/61
LVM magic value at 5927/176/1
LVM magic value at 5927/176/4
LVM magic value at 5927/176/7
LVM magic value at 5927/176/10
LVM magic value at 5927/176/13
LVM magic value at 5927/176/16
LVM magic value at 5927/176/19
LVM magic value at 5927/176/25
LVM magic value at 5927/176/28
LVM magic value at 5927/176/31
LVM magic value at 5927/176/37
LVM magic value at 5927/176/40
LVM magic value at 5927/176/43
LVM magic value at 5927/176/46
LVM magic value at 5927/176/49
LVM magic value at 5927/176/52
LVM magic value at 5927/176/55
LVM magic value at 5927/177/1
LVM magic value at 5927/177/4
LVM magic value at 5927/177/7
LVM magic value at 5927/177/10
recover_EXT2: s_block_group_nr=0/20, s_mnt_count=1/21, s_blocks_per_group=8192, s_inodes_per_group=2024
recover_EXT2: s_blocks_count 169984
recover_EXT2: part_size 339968
Filesystem created: Fri Jan 4 06:06:38 2013
Last mount time: Fri Jan 4 06:06:40 2013
Linux filesys. data 95581696 95921663 339968 [root]
ext4 blocksize=1024 Sparse_SB, 174 MB / 166 MiB
LVM magic value at 5980/140/49
LVM magic value at 5980/140/52
LVM magic value at 5980/140/58
LVM magic value at 5980/141/1
LVM magic value at 5980/141/7
LVM magic value at 5980/141/10
LVM magic value at 5980/141/16
LVM magic value at 5980/141/19
LVM magic value at 5980/141/22
LVM magic value at 5980/141/25
LVM magic value at 5980/141/28
LVM magic value at 5980/141/31
LVM magic value at 5980/141/37
LVM magic value at 5980/141/40
LVM magic value at 5980/141/43
LVM magic value at 5980/141/46
LVM magic value at 5980/141/49
LVM magic value at 5980/141/55
LVM magic value at 5980/141/58
LVM magic value at 5980/141/61
LVM magic value at 5980/142/1
LVM magic value at 5980/142/10
LVM magic value at 5980/142/16
LVM magic value at 5980/142/19
LVM magic value at 5980/142/22
LVM magic value at 5980/142/25
LVM magic value at 5980/142/28
LVM magic value at 5980/142/31
LVM magic value at 5980/142/34
LVM magic value at 5980/142/40
LVM magic value at 5980/142/43
LVM magic value at 5980/142/46
LVM magic value at 5980/142/49
LVM magic value at 5980/142/52
LVM magic value at 5980/142/55
LVM magic value at 5980/142/58
LVM magic value at 5980/142/61
LVM magic value at 5980/143/1
LVM magic value at 5980/143/4
LVM magic value at 5980/143/7
LVM magic value at 5980/143/13
LVM magic value at 5980/143/16
LVM magic value at 5980/143/19
LVM magic value at 5980/143/22
LVM magic value at 5980/143/25
LVM magic value at 5980/143/28
LVM magic value at 5980/143/31
LVM magic value at 5980/143/34
LVM magic value at 5980/143/37
LVM magic value at 5980/143/40
LVM magic value at 5980/143/43
LVM magic value at 5980/143/46
LVM magic value at 5980/143/49
LVM magic value at 5980/143/52
LVM magic value at 5980/143/55
LVM magic value at 5980/143/58
LVM magic value at 5980/143/61
LVM magic value at 5980/144/1
LVM magic value at 5980/144/7
LVM magic value at 5980/144/10
LVM magic value at 5980/144/13
LVM magic value at 5980/144/16
LVM magic value at 5980/144/22
LVM magic value at 5980/144/25
LVM magic value at 5980/144/28
LVM magic value at 5980/144/31
LVM magic value at 5980/144/37
LVM magic value at 5980/144/40
LVM magic value at 5980/144/43
LVM magic value at 5980/144/46
LVM magic value at 5980/144/49
LVM magic value at 5980/144/52
LVM magic value at 6049/249/5
LVM magic value at 6517/179/24
LVM magic value at 6517/180/56
LVM magic value at 6517/181/6
LVM magic value at 6517/181/12
LVM magic value at 6517/181/24
LVM magic value at 6517/181/33
LVM magic value at 6517/181/36
LVM magic value at 6517/181/42
LVM magic value at 6517/181/48
LVM magic value at 6517/181/54
LVM magic value at 6517/181/57
LVM magic value at 6517/181/63
LVM magic value at 6517/182/5
LVM magic value at 6517/182/8
LVM magic value at 6517/182/11
LVM magic value at 6517/182/14
LVM magic value at 6517/182/20
LVM magic value at 6517/182/23
LVM magic value at 6517/182/26
LVM magic value at 6517/182/32
LVM magic value at 6517/182/35
LVM magic value at 6517/182/38
LVM magic value at 6517/182/41
LVM magic value at 6517/182/50
LVM magic value at 6517/182/53
LVM magic value at 6517/182/56
LVM magic value at 6517/182/59
LVM magic value at 6517/182/62
LVM magic value at 6517/183/2
LVM magic value at 6517/183/5
LVM magic value at 6517/183/8
LVM magic value at 6517/183/11
LVM magic value at 6517/183/14
LVM magic value at 6517/183/17
LVM magic value at 6517/183/20
LVM magic value at 6517/183/23
LVM magic value at 6517/183/26
LVM magic value at 6517/183/29
LVM magic value at 6517/183/32
LVM magic value at 6517/183/35
LVM magic value at 6517/183/38
LVM magic value at 6517/183/41
LVM magic value at 6517/183/44
LVM magic value at 6517/183/47
LVM magic value at 6517/183/50
LVM magic value at 6517/183/53
LVM magic value at 6517/183/56
LVM magic value at 6517/183/59
LVM magic value at 6517/183/62
LVM magic value at 6517/184/2
LVM magic value at 6517/184/5
LVM magic value at 6517/184/11
LVM magic value at 6517/184/14
LVM magic value at 6517/184/17
LVM magic value at 6517/184/20
LVM magic value at 6517/184/23
LVM magic value at 6517/184/26
LVM magic value at 6517/184/29
LVM magic value at 6517/184/32
LVM magic value at 6517/184/35
LVM magic value at 6517/184/38
LVM magic value at 6517/184/41
LVM magic value at 6517/184/44
LVM magic value at 6517/184/47
LVM magic value at 6632/252/26
LVM magic value at 6632/252/32
LVM magic value at 6632/252/44
LVM magic value at 6632/252/53
LVM magic value at 6632/252/56
LVM magic value at 6632/252/62
LVM magic value at 6632/253/5
LVM magic value at 6632/253/11
LVM magic value at 6632/253/14
LVM magic value at 6632/253/20
LVM magic value at 6632/253/23
LVM magic value at 6632/253/26
LVM magic value at 6632/253/29
LVM magic value at 6632/253/32
LVM magic value at 6632/253/35
LVM magic value at 6632/253/41
LVM magic value at 6632/253/44
LVM magic value at 6632/253/47
LVM magic value at 6632/253/50
LVM magic value at 6632/253/53
LVM magic value at 6632/253/59
LVM magic value at 6632/253/62
LVM magic value at 6632/254/2
LVM magic value at 6632/254/5
LVM magic value at 6632/254/14
LVM magic value at 6632/254/20
LVM magic value at 6632/254/23
LVM magic value at 6632/254/26
LVM magic value at 6632/254/29
LVM magic value at 6632/254/32
LVM magic value at 6632/254/35
LVM magic value at 6632/254/38
LVM magic value at 6632/254/44
LVM magic value at 6632/254/47
LVM magic value at 6632/254/50
LVM magic value at 6632/254/53
LVM magic value at 6632/254/56
LVM magic value at 6632/254/59
LVM magic value at 6632/254/62
LVM magic value at 6633/0/2
LVM magic value at 6633/0/5
LVM magic value at 6633/0/8
LVM magic value at 6633/0/11
LVM magic value at 6633/0/17
LVM magic value at 6633/0/20
LVM magic value at 6633/0/23
LVM magic value at 6633/0/26
LVM magic value at 6633/0/29
LVM magic value at 6633/0/32
LVM magic value at 6633/0/35
LVM magic value at 6633/0/38
LVM magic value at 6633/0/41
LVM magic value at 6633/0/44
LVM magic value at 6633/0/47
LVM magic value at 6633/0/50
LVM magic value at 6633/0/53
LVM magic value at 6633/0/56
LVM magic value at 6633/0/59
LVM magic value at 6633/0/62
LVM magic value at 6633/1/2
LVM magic value at 6633/1/5
LVM magic value at 6633/1/11
LVM magic value at 6633/1/14
LVM magic value at 6633/1/17
LVM magic value at 6633/1/20
recover_EXT2: s_block_group_nr=0/16, s_mnt_count=14/32, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 524288
recover_EXT2: part_size 4194304
Filesystem created: Wed Jun 26 14:22:42 2013
Last mount time: Mon Apr 27 03:04:11 2015
Linux filesys. data 116461608 120655911 4194304 [Data]
ext4 blocksize=4096 Large_file Sparse_SB Recover, 2147 MB / 2048 MiB
LVM magic value at 7547/246/21
LVM magic value at 7547/247/53
LVM magic value at 7547/248/3
LVM magic value at 7547/248/9
LVM magic value at 7547/248/21
LVM magic value at 7547/248/30
LVM magic value at 7547/248/33
LVM magic value at 7547/248/39
LVM magic value at 7547/248/45
LVM magic value at 7547/248/51
LVM magic value at 7547/248/54
LVM magic value at 7547/248/60
LVM magic value at 7547/249/2
LVM magic value at 7547/249/5
LVM magic value at 7547/249/8
LVM magic value at 7547/249/11
LVM magic value at 7547/249/17
LVM magic value at 7547/249/20
LVM magic value at 7547/249/23
LVM magic value at 7547/249/29
LVM magic value at 7547/249/32
LVM magic value at 7547/249/35
LVM magic value at 7547/249/38
LVM magic value at 7547/249/47
LVM magic value at 7547/249/50
LVM magic value at 7547/249/53
LVM magic value at 7547/249/56
LVM magic value at 7547/249/59
LVM magic value at 7547/249/62
LVM magic value at 7547/250/2
LVM magic value at 7547/250/5
LVM magic value at 7547/250/8
LVM magic value at 7547/250/11
LVM magic value at 7547/250/14
LVM magic value at 7547/250/17
LVM magic value at 7547/250/20
LVM magic value at 7547/250/23
LVM magic value at 7547/250/26
LVM magic value at 7547/250/29
LVM magic value at 7547/250/32
LVM magic value at 7547/250/35
LVM magic value at 7547/250/38
LVM magic value at 7547/250/41
LVM magic value at 7547/250/44
LVM magic value at 7547/250/47
LVM magic value at 7547/250/50
LVM magic value at 7547/250/53
LVM magic value at 7547/250/56
LVM magic value at 7547/250/59
LVM magic value at 7547/250/62
LVM magic value at 7547/251/2
LVM magic value at 7547/251/8
LVM magic value at 7547/251/11
LVM magic value at 7547/251/14
LVM magic value at 7547/251/17
LVM magic value at 7547/251/20
LVM magic value at 7547/251/23
LVM magic value at 7547/251/26
LVM magic value at 7547/251/29
LVM magic value at 7547/251/32
LVM magic value at 7547/251/35
LVM magic value at 7547/251/38
LVM magic value at 7547/251/41
LVM magic value at 7547/251/44
LVM magic value at 7621/119/58
LVM magic value at 7621/120/1
LVM magic value at 7621/120/4
LVM magic value at 7621/120/10
LVM magic value at 7621/120/13
LVM magic value at 7621/120/16
LVM magic value at 7621/120/22
LVM magic value at 7621/120/28
LVM magic value at 7621/120/31
LVM magic value at 7621/120/34
LVM magic value at 7621/120/43
LVM magic value at 7621/120/46
LVM magic value at 7621/120/49
LVM magic value at 7621/120/52
LVM magic value at 7621/120/55
LVM magic value at 7621/120/58
LVM magic value at 7621/120/61
LVM magic value at 7621/121/1
LVM magic value at 7621/121/4
LVM magic value at 7621/121/7
LVM magic value at 7621/121/13
LVM magic value at 7621/121/16
LVM magic value at 7621/121/19
LVM magic value at 7621/121/22
LVM magic value at 7621/121/25
LVM magic value at 7621/121/28
LVM magic value at 7621/121/31
LVM magic value at 7621/121/34
LVM magic value at 7621/121/37
LVM magic value at 7621/121/40
LVM magic value at 7621/121/43
LVM magic value at 7621/121/46
LVM magic value at 7621/121/49
LVM magic value at 7621/121/52
LVM magic value at 7621/121/55
LVM magic value at 7621/121/58
LVM magic value at 7621/121/61
LVM magic value at 7621/122/4
LVM magic value at 7621/122/7
LVM magic value at 7621/122/10
LVM magic value at 7621/148/18
LVM magic value at 7621/148/21
LVM magic value at 7621/148/24
LVM magic value at 7621/148/30
LVM magic value at 7621/148/33
LVM magic value at 7621/148/39
LVM magic value at 7621/148/45
LVM magic value at 7621/148/48
LVM magic value at 7621/148/51
LVM magic value at 7621/148/54
LVM magic value at 7621/148/63
LVM magic value at 7621/149/3
LVM magic value at 7621/149/6
LVM magic value at 7621/149/12
LVM magic value at 7621/149/15
LVM magic value at 7621/149/21
LVM magic value at 7621/149/42
LVM magic value at 7621/149/45
LVM magic value at 7621/149/48
LVM magic value at 7621/149/51
LVM magic value at 7621/149/54
LVM magic value at 7621/149/63
LVM magic value at 7621/150/6
LVM magic value at 7621/150/12
LVM magic value at 7621/150/18
LVM magic value at 7621/150/21
LVM magic value at 7621/150/24
LVM magic value at 7621/150/27
LVM magic value at 7621/150/33
LVM magic value at 7621/150/36
LVM magic value at 7621/150/39
LVM magic value at 7621/150/42
LVM magic value at 7621/150/45
LVM magic value at 7621/150/48
LVM magic value at 7621/150/51
LVM magic value at 7621/150/54
LVM magic value at 7621/150/57
LVM magic value at 7621/150/60
LVM magic value at 7621/150/63
LVM magic value at 7621/151/3
LVM magic value at 7621/151/9
LVM magic value at 7621/151/12
LVM magic value at 7621/151/15
LVM magic value at 7621/151/18
LVM magic value at 7621/151/21
LVM magic value at 7621/151/24
LVM magic value at 7621/151/27
LVM magic value at 7621/151/30
LVM magic value at 7621/151/33
LVM magic value at 7621/151/39
LVM magic value at 7621/151/42
LVM magic value at 7621/151/45
LVM magic value at 7621/151/48
LVM magic value at 7621/151/51
LVM magic value at 7621/151/54
LVM magic value at 7621/151/57
LVM magic value at 7621/151/60
LVM magic value at 7621/152/3
LVM magic value at 7621/152/6
LVM magic value at 7621/152/9
LVM magic value at 7621/152/15
LVM magic value at 7621/152/18
LVM magic value at 7882/172/60
LVM magic value at 7882/173/38
LVM magic value at 7882/173/41
LVM magic value at 7882/173/44
LVM magic value at 7882/173/47
LVM magic value at 7882/173/50
LVM magic value at 7882/173/53
LVM magic value at 7882/173/56
LVM magic value at 7882/173/59
LVM magic value at 7882/173/62
LVM magic value at 7882/174/2
LVM magic value at 7882/174/5
LVM magic value at 7882/174/8
LVM magic value at 7882/174/11
LVM magic value at 7882/174/14
LVM magic value at 7882/174/17
LVM magic value at 7882/174/23
LVM magic value at 7882/174/26
LVM magic value at 7882/174/29
LVM magic value at 7882/174/32
LVM magic value at 7882/174/38
LVM magic value at 7882/174/41
LVM magic value at 7882/174/44
LVM magic value at 7882/174/47
LVM magic value at 7882/174/53
LVM magic value at 7882/174/56
LVM magic value at 7882/174/59
LVM magic value at 7882/174/62
LVM magic value at 7882/175/2
LVM magic value at 7882/175/5
LVM magic value at 7882/175/8
LVM magic value at 7882/175/11
LVM magic value at 7882/175/14
LVM magic value at 7882/175/17
LVM magic value at 7882/175/20
LVM magic value at 7882/175/23
LVM magic value at 7882/175/26
LVM magic value at 7882/175/29
LVM magic value at 7882/175/32
LVM magic value at 7882/175/35
LVM magic value at 7882/175/41
LVM magic value at 7882/175/44
LVM magic value at 7882/175/47
LVM magic value at 7882/175/50
LVM magic value at 7882/175/56
LVM magic value at 7882/175/59
LVM magic value at 7882/175/62
LVM magic value at 7882/176/5
LVM magic value at 7882/176/8
LVM magic value at 7882/176/11
LVM magic value at 7882/176/14
LVM magic value at 7882/176/23
LVM magic value at 7882/176/26
LVM magic value at 7882/176/29
LVM magic value at 7882/176/32
LVM magic value at 7882/176/35
LVM magic value at 7882/176/38
LVM magic value at 7882/176/41
LVM magic value at 7882/176/44
LVM magic value at 7882/176/47
LVM magic value at 7882/176/50
LVM magic value at 7882/176/53
LVM magic value at 7882/176/56
LVM magic value at 7882/176/59
LVM magic value at 7882/176/62
LVM magic value at 7882/177/2
LVM magic value at 7882/177/5
LVM magic value at 7882/177/8
LVM magic value at 7882/177/11
LVM magic value at 7882/177/14
LVM magic value at 7882/177/17
LVM magic value at 7882/177/20
LVM magic value at 7882/177/23
LVM magic value at 7882/177/26
LVM magic value at 7882/177/29
LVM magic value at 7882/177/32
LVM magic value at 7882/177/35
LVM magic value at 7882/177/38
LVM magic value at 8110/36/6
LVM magic value at 8110/36/9
LVM magic value at 8110/36/18
LVM magic value at 8110/36/30
LVM magic value at 8110/36/36
LVM magic value at 8110/36/39
LVM magic value at 8110/36/45
LVM magic value at 8110/36/48
LVM magic value at 8110/36/51
LVM magic value at 8110/36/57
LVM magic value at 8110/36/63
LVM magic value at 8110/37/3
LVM magic value at 8110/37/6
LVM magic value at 8110/37/15
LVM magic value at 8110/37/18
LVM magic value at 8110/37/21
LVM magic value at 8110/37/24
LVM magic value at 8110/37/27
LVM magic value at 8110/37/30
LVM magic value at 8110/37/33
LVM magic value at 8110/37/36
LVM magic value at 8110/37/39
LVM magic value at 8110/37/42
LVM magic value at 8110/37/48
LVM magic value at 8110/37/51
LVM magic value at 8110/37/54
LVM magic value at 8110/37/57
LVM magic value at 8110/37/60
LVM magic value at 8110/37/63
LVM magic value at 8110/38/3
LVM magic value at 8110/38/6
LVM magic value at 8110/38/9
LVM magic value at 8110/38/12
LVM magic value at 8110/38/15
LVM magic value at 8110/38/18
LVM magic value at 8110/38/21
LVM magic value at 8110/38/24
LVM magic value at 8110/38/27
LVM magic value at 8110/38/30
LVM magic value at 8110/38/33
LVM magic value at 8110/38/39
LVM magic value at 8110/38/42
LVM magic value at 8110/38/45
LVM magic value at 8110/64/35
LVM magic value at 8110/64/44
LVM magic value at 8110/64/47
LVM magic value at 8110/64/53
LVM magic value at 8110/64/56
LVM magic value at 8110/64/59
LVM magic value at 8110/65/2
LVM magic value at 8110/65/5
LVM magic value at 8110/65/11
LVM magic value at 8110/65/17
LVM magic value at 8110/65/20
LVM magic value at 8110/65/23
LVM magic value at 8110/65/26
LVM magic value at 8110/65/35
LVM magic value at 8110/65/38
LVM magic value at 8110/65/41
LVM magic value at 8110/65/47
LVM magic value at 8110/65/50
LVM magic value at 8110/65/56
LVM magic value at 8110/66/14
LVM magic value at 8110/66/17
LVM magic value at 8110/66/20
LVM magic value at 8110/66/23
LVM magic value at 8110/66/26
LVM magic value at 8110/66/35
LVM magic value at 8110/66/41
LVM magic value at 8110/66/47
LVM magic value at 8110/66/53
LVM magic value at 8110/66/56
LVM magic value at 8110/66/59
LVM magic value at 8110/66/62
LVM magic value at 8110/67/5
LVM magic value at 8110/67/8
LVM magic value at 8110/67/11
LVM magic value at 8110/67/14
LVM magic value at 8110/67/17
LVM magic value at 8110/67/20
LVM magic value at 8110/67/23
LVM magic value at 8110/67/26
LVM magic value at 8110/67/29
LVM magic value at 8110/67/32
LVM magic value at 8110/67/35
LVM magic value at 8110/67/38
LVM magic value at 8110/67/44
LVM magic value at 8110/67/47
LVM magic value at 8110/67/50
LVM magic value at 8110/67/53
LVM magic value at 8110/67/56
LVM magic value at 8110/67/59
LVM magic value at 8110/67/62
LVM magic value at 8110/68/2
LVM magic value at 8110/68/5
LVM magic value at 8110/68/11
LVM magic value at 8110/68/14
LVM magic value at 8110/68/17
LVM magic value at 8110/68/20
LVM magic value at 8376/117/13
LVM magic value at 8376/117/16
LVM magic value at 8376/117/25
LVM magic value at 8376/117/37
LVM magic value at 8376/117/43
LVM magic value at 8376/117/46
LVM magic value at 8376/117/52
LVM magic value at 8376/117/55
LVM magic value at 8376/117/58
LVM magic value at 8376/118/1
LVM magic value at 8376/118/7
LVM magic value at 8376/118/10
LVM magic value at 8376/118/13
LVM magic value at 8376/118/22
LVM magic value at 8376/118/25
LVM magic value at 8376/118/28
LVM magic value at 8376/118/31
LVM magic value at 8376/118/34
LVM magic value at 8376/118/37
LVM magic value at 8376/118/40
LVM magic value at 8376/118/43
LVM magic value at 8376/118/46
LVM magic value at 8376/118/49
LVM magic value at 8376/118/55
LVM magic value at 8376/118/58
LVM magic value at 8376/118/61
LVM magic value at 8376/144/47
LVM magic value at 8376/145/9
LVM magic value at 8376/145/14
LVM magic value at 8376/145/24
LVM magic value at 8376/145/42
LVM magic value at 8376/145/51
LVM magic value at 8376/145/54
LVM magic value at 8376/145/60
LVM magic value at 8376/145/63
LVM magic value at 8376/146/3
LVM magic value at 8376/146/9
LVM magic value at 8376/146/12
LVM magic value at 8376/146/18
LVM magic value at 8376/146/24
LVM magic value at 8376/146/27
LVM magic value at 8376/146/30
LVM magic value at 8376/146/33
LVM magic value at 8376/146/42
LVM magic value at 8376/146/45
LVM magic value at 8376/146/48
LVM magic value at 8376/146/54
LVM magic value at 8376/146/57
LVM magic value at 8376/146/63
LVM magic value at 8376/147/21
LVM magic value at 8376/147/24
LVM magic value at 8376/147/27
LVM magic value at 8376/147/29
LVM magic value at 8376/147/32
LVM magic value at 8376/147/35
LVM magic value at 8376/147/38
LVM magic value at 8376/147/41
LVM magic value at 8376/147/44
LVM magic value at 8376/147/47
LVM magic value at 8376/147/50
LVM magic value at 8376/147/53
LVM magic value at 8376/147/56
LVM magic value at 8376/147/59
LVM magic value at 8376/147/62
LVM magic value at 8376/148/2
LVM magic value at 8376/148/5
LVM magic value at 8376/148/8
LVM magic value at 8376/148/14
LVM magic value at 8376/148/17
LVM magic value at 8376/148/23
LVM magic value at 8376/148/29
LVM magic value at 8376/148/32
LVM magic value at 8376/148/35
LVM magic value at 8376/148/38
LVM magic value at 8376/148/44
LVM magic value at 8376/148/47
LVM magic value at 8376/148/50
LVM magic value at 8376/148/53
LVM magic value at 8376/148/56
LVM magic value at 8376/148/59
LVM magic value at 8376/148/62
LVM magic value at 8516/175/37
LVM magic value at 8516/177/6
LVM magic value at 8516/177/19
LVM magic value at 8516/177/25
LVM magic value at 8516/177/37
LVM magic value at 8516/177/48
LVM magic value at 8516/177/51
LVM magic value at 8516/177/54
LVM magic value at 8516/177/57
LVM magic value at 8516/177/60
LVM magic value at 8516/177/63
LVM magic value at 8516/178/3
LVM magic value at 8516/178/6
LVM magic value at 8516/178/9
LVM magic value at 8516/178/12
LVM magic value at 8516/178/18
LVM magic value at 8516/178/21
LVM magic value at 8516/178/24
LVM magic value at 8516/178/27
LVM magic value at 8516/178/33
LVM magic value at 8516/178/36
LVM magic value at 8516/178/39
LVM magic value at 8516/178/45
LVM magic value at 8516/178/48
LVM magic value at 8516/178/51
LVM magic value at 8516/178/54
LVM magic value at 8516/178/63
LVM magic value at 8516/179/3
LVM magic value at 8516/179/6
LVM magic value at 8516/179/9
LVM magic value at 8516/179/12
LVM magic value at 8516/179/15
LVM magic value at 8516/179/18
LVM magic value at 8516/179/21
LVM magic value at 8516/179/24
LVM magic value at 8516/179/27
LVM magic value at 8516/179/30
LVM magic value at 8516/179/33
LVM magic value at 8516/179/36
LVM magic value at 8516/179/39
LVM magic value at 8516/179/42
LVM magic value at 8516/179/45
LVM magic value at 8516/179/48
LVM magic value at 8516/179/51
LVM magic value at 8516/179/54
LVM magic value at 8516/179/57
LVM magic value at 8516/179/60
LVM magic value at 8516/179/63
LVM magic value at 8516/180/3
LVM magic value at 8516/180/6
LVM magic value at 8516/180/9
LVM magic value at 8516/180/12
LVM magic value at 8516/180/15
LVM magic value at 8516/180/18
LVM magic value at 8516/180/24
LVM magic value at 8516/180/27
LVM magic value at 8516/180/30
LVM magic value at 8516/180/33
LVM magic value at 8516/180/36
LVM magic value at 8516/180/39
LVM magic value at 8516/180/42
LVM magic value at 8516/180/45
LVM magic value at 8516/180/48
LVM magic value at 8516/180/51
LVM magic value at 8516/180/54
LVM magic value at 8516/180/57
LVM magic value at 8516/180/60
Unknown 155563094 23448460007421013 23448459851857920
WBFS, 12005611 TB / 10919040 TiB
Partition not added.
NTFS at 9774/158/49
mft_lcn 51200
mftmirr_lcn 2
MS Data 155800513 157029312 1228800
NTFS found using backup sector, blocksize=4096, 629 MB / 600 MiB
NTFS at 9774/158/49
mft_lcn 51200
mftmirr_lcn 2
MS Data 157029312 158258111 1228800
Linux filesys. data 164370184 168564487 4194304 [Data]
HFS magic value at 10728/7/29
part_size 4261410380
Mac HFS 172345789 4433756168 4261410380 [D^]
HFS blocksize=33554432, 2181 GB / 2031 GiB
This partition ends after the disk limits. (start=172345789, size=4261410380, end=4433756168, disk end=250069680)
HFS magic value at 10728/7/31
LVM magic value at 11652/233/43
LVM magic value at 11652/233/61
LVM magic value at 11652/234/13
LVM magic value at 11652/234/28
LVM magic value at 11652/234/46
LVM magic value at 11652/234/61
LVM magic value at 11652/235/13
LVM magic value at 12063/188/35
NTFS at 13102/187/22
mft_lcn 51200
mftmirr_lcn 2
MS Data 209266633 210495432 1228800
mft_lcn 51200
mftmirr_lcn 2
MS Data 210495432 211724231 1228800
NTFS at 13776/13/22
mft_lcn 51200
mftmirr_lcn 2
MS Data 220083481 221312280 1228800
NTFS at 13776/13/22
mft_lcn 51200
mftmirr_lcn 2
MS Data 221312280 222541079 1228800
LVM magic value at 15255/41/46
NTFS at 15506/123/34
mft_lcn 2058
mftmirr_lcn 5162
MS Data 249105499 249111672 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 249111672 249117845 6174
NTFS at 15536/93/62
mft_lcn 2058
mftmirr_lcn 5162
MS Data 249585587 249591760 6174
NTFS at 15536/93/62
mft_lcn 2058
mftmirr_lcn 5162
MS Data 249591760 249597933 6174
NTFS at 15537/2/17
filesystem size 989184
mft_lcn 41216
mftmirr_lcn 2
MS Data 248612864 249602047 989184
NTFS found using backup sector, blocksize=4096, 506 MB / 483 MiB
NTFS at 15537/2/17
mft_lcn 41216
mftmirr_lcn 2
MS Data 249602047 250591230 989184
NTFS, blocksize=4096, 506 MB / 483 MiB
This partition ends after the disk limits. (start=249602047, size=989184, end=250591230, disk end=250069680)
NTFS at 15565/192/51
filesystem size 923648
mft_lcn 38485
mftmirr_lcn 2
MS Data 249140224 250063871 923648
NTFS found using backup sector, blocksize=4096, 472 MB / 451 MiB
mft_lcn 38485
mftmirr_lcn 2
NTFS: Can't read MFT
MS Data 250063871 250987518 923648
NTFS, blocksize=4096, 472 MB / 451 MiB
This partition ends after the disk limits. (start=250063871, size=923648, end=250987518, disk end=250069680)
The harddisk (128 GB / 119 GiB) seems too small! (< 2270 GB / 2114 GiB)
P MS Data 615423 1844222 1228800
P Linux filesys. data 7604937 8976920 1371984 [GW¹¤Ø«ÝнÍ(bždSÜ]
P MS Data 14030068 14050806 20739 [NO NAME]
P MS Data 16001528 16004407 2880 [NO NAME]
P MS Data 24718760 24721639 2880 [NO NAME]
P MS Data 30789768 30792647 2880 [NO NAME]
P Linux filesys. data 94340992 94545791 204800 [root]
P Linux filesys. data 95581696 95921663 339968 [root]
P Linux filesys. data 116461608 120655911 4194304 [Data]
P Linux filesys. data 164370184 168564487 4194304 [Data]
echo "0 6174 linear /dev/sdb 16267" | dmsetup create test0
echo "0 6174 linear /dev/sdb 22440" | dmsetup create test1
echo "0 1228800 linear /dev/sdb 615423" | dmsetup create test2
echo "0 1371984 linear /dev/sdb 7604937" | dmsetup create test3
echo "0 20739 linear /dev/sdb 14030068" | dmsetup create test4
echo "0 2880 linear /dev/sdb 16001528" | dmsetup create test5
echo "0 6174 linear /dev/sdb 16518867" | dmsetup create test6
echo "0 6174 linear /dev/sdb 16525040" | dmsetup create test7
echo "0 2880 linear /dev/sdb 24718760" | dmsetup create test8
echo "0 2880 linear /dev/sdb 30789768" | dmsetup create test9
echo "0 6174 linear /dev/sdb 59931411" | dmsetup create test10
echo "0 6174 linear /dev/sdb 59937584" | dmsetup create test11
echo "0 6174 linear /dev/sdb 71455683" | dmsetup create test12
echo "0 6174 linear /dev/sdb 71461856" | dmsetup create test13
echo "0 204800 linear /dev/sdb 94340992" | dmsetup create test14
echo "0 339968 linear /dev/sdb 95581696" | dmsetup create test15
echo "0 4194304 linear /dev/sdb 116461608" | dmsetup create test16
echo "0 1228800 linear /dev/sdb 155800513" | dmsetup create test17
echo "0 1228800 linear /dev/sdb 157029312" | dmsetup create test18
echo "0 4194304 linear /dev/sdb 164370184" | dmsetup create test19
echo "0 1228800 linear /dev/sdb 209266633" | dmsetup create test20
echo "0 1228800 linear /dev/sdb 210495432" | dmsetup create test21
echo "0 1228800 linear /dev/sdb 220083481" | dmsetup create test22
echo "0 1228800 linear /dev/sdb 221312280" | dmsetup create test23
echo "0 989184 linear /dev/sdb 248612864" | dmsetup create test24
echo "0 6174 linear /dev/sdb 249105499" | dmsetup create test25
echo "0 6174 linear /dev/sdb 249111672" | dmsetup create test26
echo "0 923648 linear /dev/sdb 249140224" | dmsetup create test27
echo "0 6174 linear /dev/sdb 249585587" | dmsetup create test28
echo "0 6174 linear /dev/sdb 249591760" | dmsetup create test29
1 P MS Data 615423 1844222 1228800
2 P Linux filesys. data 7604937 8976920 1371984 [GW¹¤Ø«ÝнÍ(bždSÜ]
3 P MS Data 14030068 14050806 20739 [NO NAME]
4 P MS Data 16001528 16004407 2880 [NO NAME]
5 P MS Data 24718760 24721639 2880 [NO NAME]
6 P MS Data 30789768 30792647 2880 [NO NAME]
7 P Linux filesys. data 94340992 94545791 204800 [root]
8 P Linux filesys. data 95581696 95921663 339968 [root]
9 P Linux filesys. data 116461608 120655911 4194304 [Data]
10 P Linux filesys. data 164370184 168564487 4194304 [Data]
write!
Compiler: GCC 9.2
NTFS at 1/101/13
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 1/101/13
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 15/171/61
mftmirr_lcn 2
NTFS at 15/171/61
mftmirr_lcn 2
NTFS at 38/78/40
mft_lcn 51200
mftmirr_lcn 2
NTFS at 38/78/40
mft_lcn 51200
mftmirr_lcn 2
recover_cramfs
FAT12 at 873/84/32
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
FAT12 at 873/84/32
FAT12 at 996/12/33
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 996/12/33
NTFS at 1028/162/15
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 1028/162/15
mft_lcn 2058
mftmirr_lcn 5162
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
NTFS at 3730/240/15
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 3730/240/15
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 4448/75/12
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 4448/75/12
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 9774/158/49
mft_lcn 51200
mftmirr_lcn 2
NTFS at 9774/158/49
mft_lcn 51200
mftmirr_lcn 2
mft_lcn 51200
mftmirr_lcn 2
mft_lcn 51200
mftmirr_lcn 2
NTFS at 13776/13/22
mft_lcn 51200
mftmirr_lcn 2
NTFS at 13776/13/22
mft_lcn 51200
mftmirr_lcn 2
mft_lcn 2058
mftmirr_lcn 5162
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 15536/93/62
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 15536/93/62
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 15537/2/17
mft_lcn 41216
mftmirr_lcn 2
NTFS at 15537/2/17
mft_lcn 41216
mftmirr_lcn 2
mft_lcn 38485
mftmirr_lcn 2
mft_lcn 38485
mftmirr_lcn 2
write!
