Does this indicate a problem with Windows Reserved Partition on secondary drive?
DonaldH
#1 Post by DonaldH »
TLDR: I messed up my hard drive, I used TestDisk and I believe I was able to fix it. Everything seems to be working correctly but there is an error ("No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker") reported on my second drive's Microsoft Reserved Partition. I'm not sure if this is normal or if it indicates a problem I should fix.
Here is the contents of a current testdisk.log:
Sat Oct  9 14:24:48 2021
TestDisk 7.2-WIP, Data Recovery Utility, September 2021
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255351507456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=524288000
Disk \\.\PhysicalDrive0 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - HGST HDS724040ALE640, S/N:PK1331PAJD4JJS, FW:MJAOA580
Disk \\.\PhysicalDrive1 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - Samsung SSD 840 PRO Series, S/N:S12RNEAD701008K, FW:DXM05B0Q
Drive G: - 524 MB / 500 MiB - CHS 16000 2 32, sector size=512
Disk \\.\PhysicalDrive0 - 4000 GB / 3726 GiB - HGST HDS724040ALE640
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive0 - 4000 GB / 3726 GiB - CHS 486401 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814037167 (expected 7814037167)
hdr_lba_start=34
hdr_lba_end=7814037134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
 2 P MS Data                   264192 7814035455 7813771264 [Basic data partition] [Frozen]
Backup partition structure
partition_save
NTFS at 16/113/34
filesystem size           7813771264
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=135266304, part_size=4000650887168, sector_size=512
NTFS at 16/113/34
mftmirr_lcn               2
     MS Data                   264192 7814035455 7813771264 [Frozen]
     NTFS, blocksize=4096, 4000 GB / 3725 GiB
   P MS Data                   264192 7814035455 7813771264 [Frozen]
 1 P MS Data                   264192 7814035455 7813771264 [Frozen]
A little more detailed description of what happened: My computer currently has two physical drives:
- a 256GB SSD (C drive) which is the main/system drive with Windows 10 and frequently used programs
- a secondary 4TB drive (D drive) that is used to store photos, videos and all other programs
I am trying to upgrade the SSD to a 1TB SSD. I use IDrive for online backup and it has a utility that I've used to do this before so that's what I was trying to use. I went through the steps to create an image of the SSD, swap the drives and boot WinRE off a flash drive. After booting from the flash drive, the D drive became the C drive and the new blank SSD was the F drive. I was careless when I entered the command so instead of telling it to copy the image from C drive to the F drive, I accidentally entered a command to copy the image from the C drive to the C drive. It encountered errors immediately after starting and I realized what I had done. So I stopped it, swapped in my old SSD and restarted. At this point, my second drive was inaccessible and Windows said it needed to be formatted.
I searched, found TestDisk, after doing a scan, saw that the Boot sector was Bad but the Backup boot sector was OK. I was able to copy the Backup boot sector to the Boot sector and after restarting my PC everything seemed back to normal. I've been running it for over a week now and haven't noticed any issued with my files or programs installed on that drive. My only concern is that TestDisk reports "No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker" for the Microsoft Reserved Partition (MSR) on the second drive. (There is also a reserved partition on the SSD that doesn't report any errors.) Does that mean there is still a problem or is this normal with the MSR on a secondary drive? Various sources on the internet have conflicting information whether this partition is necessary or not.
Re: Does this indicate a problem with Windows Reserved Partition on secondary drive?
DonaldH wrote: 09 Oct 2021, 23:59 TLDR: I messed up my hard drive, I used TestDisk and I believe I was able to fix it. Everything seems to be working correctly but there is an error ("No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker") reported on my second drive's Microsoft Reserved Partition.
Is your operating system reporting an error?
I don't have any system with a "Microsoft reserved partition" and can't tell you. Just run Testdisk on a known healthy system to answer the question what "normal" is.
