A quick summary:
I wrote onto EFI System Partition with dd command. I started Ubuntu with usb and check the partition with gparted.
It was like the following image.
After that I deleted the /dev/sda1 EFI with gparted.
/dev/sda2 ext4(ubuntu) was okay and still there.
And then I unmounted /dev/sda2 ext4(ubuntu) with gparted.
After I unmounted the partitions (3 of them) collapsed into 1 filesystem. And it has become unallocated (following image).
sudo gdisk -l /dev/sda' Outputs:
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sda: 976773168 sectors, 465.8 GiB
Model: Samsung SSD 860
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): xxxxx
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 976773134
Partitions will be aligned on 2048-sector boundaries
Total free space is 976773101 sectors (465.8 GiB)testdisk log:
Tue Oct 12 14:21:50 2021
Command line: TestDisk /debug
OS: Linux, kernel 5.8.0-43-generic (#49~20.04.1-Ubuntu SMP Fri Feb 5 09:57:56 UTC 2021) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.45.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 860
Disk /dev/sdb - 15 GB / 14 GiB - CHS 14664 64 32, sector size=512 - SanDisk Cruzer Force, FW:1.00
Disk /dev/loop0 - 2109 MB / 2012 MiB - 4120632 sectors (RO), sector size=512
Disk /dev/loop1 - 53 MB / 51 MiB - 104536 sectors (RO), sector size=512
Disk /dev/loop2 - 32 MB / 31 MiB - 63664 sectors (RO), sector size=512
Disk /dev/loop3 - 229 MB / 218 MiB - 448496 sectors (RO), sector size=512
Disk /dev/loop4 - 58 MB / 55 MiB - 113592 sectors (RO), sector size=512
Disk /dev/loop5 - 67 MB / 64 MiB - 132648 sectors (RO), sector size=512
Disk /dev/sda - 500 GB / 465 GiB - Samsung SSD 860 EVO 500GB
 1 P EFI GPT                  0   0  2 60801  80 63  976773167
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
recover_EXT2: s_block_group_nr=0/3722, s_mnt_count=206/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 121965056
recover_EXT2: part_size 975720448
Filesystem created: Sun Jun 21 00:15:40 2020
Last mount time:    Sat Oct  9 21:29:00 2021
     Linux                   65 101 37 60801  47 46  975720448
     ext4 blocksize=4096 Large_file Sparse_SB, 499 GB / 465 GiB
   * Linux                   65 101 37 60801  47 46  975720448
echo "0 975720448 linear /dev/sda 1050624" | dmsetup create test0
 1 * Linux                   65 101 37 60801  47 46  975720448
TestDisk exited normally.With "quick search" option I was able to reach my files.
Should I take image of a disk with testdisk? or Should I copy my files to external HDD immediately?
How can I fix this problem?
I seek your help and expertise.
Thank you,
(I've also posted on https://askubuntu.com/questions/1368452 ... -is-happen)
