by mistake i delete a file in SUSE Linux Enterprise Server 15.3 in a XFS partition
psousa
#1 Post by psousa »
Hello
Yesterday night by mistake i delete a linux virtual machine in Xen.
The host is a SUSE Linux Enterprise Server SP3 5.3.18-59.24 13-Sep-2021, and the partition of /vm is in XFS format.
The virtual machine was in /vm/grpwise/ and the file was grpwise.qcow2 with 321G.
Yesterday night i use your software testdisk-7.2-WIP.linux26-x86_64, i use the photorec_static and choose only files of type .cow (i did not find .qcow2), and i notice he detect .cow files...
Today morning (~5:09am) he says he recovery 8 files, but by the sizes i see,(42GB/25G/3.1GB/12GB/55GB/982GB), i think none is from my vm grpwise.qcow2 321GB...
Can you give me help (urgent)?
Of course i will pay your work.
Thanks
Re: by mistake i delete a file in SUSE Linux Enterprise Server 15.3 in a XFS partition
qcow2 is not a supported format. You would need to create your own signature of this type of file as described in the Testdisk manual.
For paid support please contact Christophe Grenier.
Search here, look at ("Mon CV"):
https://www.cgsecurity.org/wiki/CGSecurity:About
