Accidentally formatted to HFS on a NTFS USB external disk
laoshufujian
#1 Post by laoshufujian »
I have a 1 TB USB external hard drive. It was formatted in NTFS and used to store files (about 230 GB on it), non-bootable. Yesterday, I accidentally formatted it to HFS while trying to free 10 GB and install a Mountain Lion bootable disk bought/downloaded from APP Store. I came to this forum while searching on the net and it seems someone had similar experience and was able to recover the lost NTFS partition with helps from here. I tried the test disk and came to this screen
Screen
Screen
Screen Shot 2012-08-26 at 10.00.32 PM.png (49.7 KiB) Viewed 4145 times
Any help would be greatly appreciated.
Lao
Log file
Sun Aug 26 21:50:43 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
OS: Darwin, kernel 12.1.0 (Darwin Kernel Version 12.1.0: Tue Aug 14 13:29:55 PDT 2012; root:xnu-2050.9
Compiler: GCC 4.0
Compilation date: 2012-08-14T11:59:12
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 160 GB / 149 GiB - 312581808 sectors (RO), sector size=512
Disk /dev/disk1 - 999 GB / 930 GiB - 1952151552 sectors (RO), sector size=512
Disk /dev/rdisk0 - 160 GB / 149 GiB - 312581808 sectors (RO), sector size=512
Disk /dev/rdisk1 - 999 GB / 930 GiB - 1952151552 sectors (RO), sector size=512
Media is opened in read-only.
Disk /dev/disk1 - 999 GB / 930 GiB (RO)
Partition table type: EFI GPT
Analyse Disk /dev/disk1 - 999 GB / 930 GiB - 1952151552 sectors (RO)
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1952151551 (expected 1952151551)
hdr_lba_start=34
hdr_lba_end=1952151518
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600 [EFI System Partition]
2 P Mac HFS 409640 1951889367 1951479728 [232D65EE-A08C-4849-AFAA-0E868874D0A]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 1951479728
HFS+ blocksize=4096, 999 GB / 930 GiB
P EFI System 40 409639 409600 [EFI]
dir_partition inode=0
FAT: cluster=2(0x2), pos=6374
1 P EFI System 40 409639 409600 [EFI]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
HFS_HFSP_boot_sector
Volume header
HFS+ OK
Backup volume header
HFS+ OK
Sectors are not identical.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
NTFS at 1952138474/0/1
filesystem size 1952138412
mftmirr_lcn 122008650
NTFS: Can't read MFT
MS Data 1952138474 3904276885 1952138412
NTFS, blocksize=4096, 999 GB / 930 GiB
This partition ends after the disk limits. (start=1952138474, size=1952138412, end=3904276885, disk end=1952151552)
The harddisk (999 GB / 930 GiB) seems too small! (< 1998 GB / 1861 GiB)
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
Disk /dev/rdisk1 - 999 GB / 930 GiB (RO)
Analyse Disk /dev/rdisk1 - 999 GB / 930 GiB - 1952151552 sectors (RO)
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
Re: Accidentally formatted to HFS on a NTFS USB external dis
Run TestDisk, Advanced, select the actual HFS partition, use type to switch it to NTFS, choose Boot.
If available, choose BackupBS and confirm, otherwise try RebuildBS, List, Write and confirm if you can see your files.
If both failed, run TestDisk, Analyse, Quick Search, Deeper Search, switch the NTFS partition to P(rimary), on next screen, choose Write, confirm, Quit.
Post the new log if you have problems.
laoshufujian
#3 Post by laoshufujian »
Hi, cgrienier,
Thank you for replying my call for help. I tried to follow your suggestion, but didn't get the options/commands as you listed when I run testDisk. Here is some screen shots.
First, I tried testDisk/Advanced, selected the HFS, then type > HFS, type > NFTS, but after that, I didn't get the option of "boot". If I chose EFI instead, I did get an option of "boot"/RebuildBS, but after selecting "RebuildBS", no List/Write etc.
I then tried testDisk/Analysis/Quick Search/Deep Search, the deep search found two MS Data partition and a bunch of HFS partition with a "D". Again, I didn't see the option of "switching NTFS to P(rimary".
I am sure that I must have missed a step or two, but couldn't figure out where. Any further help would be greatly appreciated.
Here is the new log
Sun Sep 2 23:32:40 2012
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
gpt_change_part_type
Change partition type:
2 P NTFS 409640 1951889367 1951479728 [232D65EE-A08C-4849-AFAA-0E868874D0A]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
EFI System 46 409645 409600 [EFI]
HFS+ magic value at 409642/0/1
HFS+ magic value at 469311/0/1
Mac HFS 469311 1951949038 1951479728
HFS+ magic value at 469313/0/1
HFS+ magic value at 469432/0/1
Mac HFS 469432 1951949159 1951479728
HFS+ magic value at 469434/0/1
HFS+ magic value at 469617/0/1
Mac HFS 469617 1951949344 1951479728
HFS+ magic value at 469619/0/1
HFS+ magic value at 469722/0/1
Mac HFS 469722 1951949449 1951479728
HFS+ magic value at 469724/0/1
HFS+ magic value at 469803/0/1
Mac HFS 469803 1951949530 1951479728
HFS+ magic value at 469805/0/1
HFS+ magic value at 469892/0/1
Mac HFS 469892 1951949619 1951479728
HFS+ magic value at 469894/0/1
HFS+ magic value at 470053/0/1
Mac HFS 470053 1951949780 1951479728
HFS+ magic value at 470055/0/1
HFS+ magic value at 470214/0/1
Mac HFS 470214 1951949941 1951479728
HFS+ magic value at 470216/0/1
HFS+ magic value at 470375/0/1
Mac HFS 470375 1951950102 1951479728
HFS+ magic value at 470377/0/1
HFS+ magic value at 470560/0/1
Mac HFS 470560 1951950287 1951479728
HFS+ magic value at 470562/0/1
HFS+ magic value at 470705/0/1
Mac HFS 470705 1951950432 1951479728
HFS+ magic value at 470707/0/1
HFS+ magic value at 470810/0/1
Mac HFS 470810 1951950537 1951479728
HFS+ magic value at 470812/0/1
HFS+ magic value at 470915/0/1
Mac HFS 470915 1951950642 1951479728
HFS+ magic value at 470917/0/1
HFS+ magic value at 471028/0/1
Mac HFS 471028 1951950755 1951479728
HFS+ magic value at 471030/0/1
HFS+ magic value at 471173/0/1
Mac HFS 471173 1951950900 1951479728
HFS+ magic value at 471175/0/1
HFS+ magic value at 471366/0/1
Mac HFS 471366 1951951093 1951479728
HFS+ magic value at 471368/0/1
HFS+ magic value at 471495/0/1
Mac HFS 471495 1951951222 1951479728
HFS+ magic value at 471497/0/1
HFS+ magic value at 471584/0/1
Mac HFS 471584 1951951311 1951479728
HFS+ magic value at 471586/0/1
HFS+ magic value at 471785/0/1
Mac HFS 471785 1951951512 1951479728
HFS+ magic value at 471787/0/1
HFS+ magic value at 471930/0/1
Mac HFS 471930 1951951657 1951479728
HFS+ magic value at 471932/0/1
HFS+ magic value at 472027/0/1
Mac HFS 472027 1951951754 1951479728
HFS+ magic value at 472029/0/1
HFS+ magic value at 472156/0/1
Mac HFS 472156 1951951883 1951479728
HFS+ magic value at 472158/0/1
HFS+ magic value at 472325/0/1
Mac HFS 472325 1951952052 1951479728
HFS+ magic value at 472327/0/1
HFS+ magic value at 472438/0/1
Mac HFS 472438 1951952165 1951479728
HFS+ magic value at 472440/0/1
HFS+ magic value at 472599/0/1
Mac HFS 472599 1951952326 1951479728
HFS+ magic value at 472601/0/1
HFS+ magic value at 472672/0/1
Mac HFS 472672 1951952399 1951479728
HFS+ magic value at 472674/0/1
HFS+ magic value at 472737/0/1
Mac HFS 472737 1951952464 1951479728
HFS+ magic value at 472739/0/1
HFS+ magic value at 472994/0/1
Mac HFS 472994 1951952721 1951479728
HFS+ magic value at 472996/0/1
HFS+ magic value at 473083/0/1
Mac HFS 473083 1951952810 1951479728
HFS+ magic value at 473085/0/1
HFS+ magic value at 473204/0/1
Mac HFS 473204 1951952931 1951479728
HFS+ magic value at 473206/0/1
HFS+ magic value at 473325/0/1
Mac HFS 473325 1951953052 1951479728
HFS+ magic value at 473327/0/1
HFS+ magic value at 473438/0/1
Mac HFS 473438 1951953165 1951479728
HFS+ magic value at 473440/0/1
HFS+ magic value at 473503/0/1
Mac HFS 473503 1951953230 1951479728
HFS+ magic value at 473505/0/1
HFS+ magic value at 473744/0/1
Mac HFS 473744 1951953471 1951479728
HFS+ magic value at 473746/0/1
HFS+ magic value at 473833/0/1
Mac HFS 473833 1951953560 1951479728
HFS+ magic value at 473835/0/1
HFS+ magic value at 473938/0/1
Mac HFS 473938 1951953665 1951479728
HFS+ magic value at 473940/0/1
HFS+ magic value at 474203/0/1
Mac HFS 474203 1951953930 1951479728
HFS+ magic value at 474205/0/1
HFS+ magic value at 474388/0/1
Mac HFS 474388 1951954115 1951479728
HFS+ magic value at 474390/0/1
HFS+ magic value at 474477/0/1
Mac HFS 474477 1951954204 1951479728
HFS+ magic value at 474479/0/1
HFS+ magic value at 474566/0/1
Mac HFS 474566 1951954293 1951479728
HFS+ magic value at 474568/0/1
HFS+ magic value at 474759/0/1
Mac HFS 474759 1951954486 1951479728
HFS+ magic value at 474761/0/1
HFS+ magic value at 474960/0/1
Mac HFS 474960 1951954687 1951479728
HFS+ magic value at 474962/0/1
HFS+ magic value at 475081/0/1
Mac HFS 475081 1951954808 1951479728
HFS+ magic value at 475083/0/1
HFS+ magic value at 475242/0/1
Mac HFS 475242 1951954969 1951479728
HFS+ magic value at 475244/0/1
HFS+ magic value at 475355/0/1
Mac HFS 475355 1951955082 1951479728
HFS+ magic value at 475357/0/1
HFS+ magic value at 475580/0/1
Mac HFS 475580 1951955307 1951479728
HFS+ magic value at 475582/0/1
HFS+ magic value at 475805/0/1
Mac HFS 475805 1951955532 1951479728
HFS+ magic value at 475807/0/1
HFS+ magic value at 475942/0/1
Mac HFS 475942 1951955669 1951479728
HFS+ magic value at 475944/0/1
HFS+ magic value at 476167/0/1
Mac HFS 476167 1951955894 1951479728
HFS+ magic value at 476169/0/1
HFS+ magic value at 476352/0/1
Mac HFS 476352 1951956079 1951479728
HFS+ magic value at 476354/0/1
HFS+ magic value at 476521/0/1
Mac HFS 476521 1951956248 1951479728
HFS+ magic value at 476523/0/1
HFS+ magic value at 476658/0/1
Mac HFS 476658 1951956385 1951479728
HFS+ magic value at 476660/0/1
HFS+ magic value at 476795/0/1
Mac HFS 476795 1951956522 1951479728
HFS+ magic value at 476797/0/1
HFS+ magic value at 476932/0/1
Mac HFS 476932 1951956659 1951479728
HFS+ magic value at 476934/0/1
HFS+ magic value at 477093/0/1
Mac HFS 477093 1951956820 1951479728
HFS+ magic value at 477095/0/1
HFS+ magic value at 477222/0/1
Mac HFS 477222 1951956949 1951479728
HFS+ magic value at 477224/0/1
HFS+ magic value at 477351/0/1
Mac HFS 477351 1951957078 1951479728
HFS+ magic value at 477353/0/1
HFS+ magic value at 477440/0/1
Mac HFS 477440 1951957167 1951479728
HFS+ magic value at 477442/0/1
HFS+ magic value at 477561/0/1
Mac HFS 477561 1951957288 1951479728
HFS+ magic value at 477563/0/1
HFS+ magic value at 477666/0/1
Mac HFS 477666 1951957393 1951479728
HFS+ magic value at 477668/0/1
HFS+ magic value at 477819/0/1
Mac HFS 477819 1951957546 1951479728
HFS+ magic value at 477821/0/1
HFS+ magic value at 477908/0/1
Mac HFS 477908 1951957635 1951479728
HFS+ magic value at 477910/0/1
HFS+ magic value at 478077/0/1
Mac HFS 478077 1951957804 1951479728
HFS+ magic value at 478079/0/1
HFS+ magic value at 478342/0/1
Mac HFS 478342 1951958069 1951479728
HFS+ magic value at 478344/0/1
HFS+ magic value at 478471/0/1
Mac HFS 478471 1951958198 1951479728
HFS+ magic value at 478473/0/1
HFS+ magic value at 478536/0/1
Mac HFS 478536 1951958263 1951479728
HFS+ magic value at 478538/0/1
HFS+ magic value at 478745/0/1
Mac HFS 478745 1951958472 1951479728
HFS+ magic value at 478747/0/1
HFS+ magic value at 478850/0/1
Mac HFS 478850 1951958577 1951479728
HFS+ magic value at 478852/0/1
HFS+ magic value at 478971/0/1
Mac HFS 478971 1951958698 1951479728
HFS+ magic value at 478973/0/1
HFS+ magic value at 479068/0/1
Mac HFS 479068 1951958795 1951479728
HFS+ magic value at 479070/0/1
HFS+ magic value at 479197/0/1
Mac HFS 479197 1951958924 1951479728
HFS+ magic value at 479199/0/1
HFS+ magic value at 479310/0/1
Mac HFS 479310 1951959037 1951479728
HFS+ magic value at 479312/0/1
HFS+ magic value at 479399/0/1
Mac HFS 479399 1951959126 1951479728
HFS+ magic value at 479401/0/1
HFS+ magic value at 479568/0/1
Mac HFS 479568 1951959295 1951479728
HFS+ magic value at 479570/0/1
HFS+ magic value at 479673/0/1
Mac HFS 479673 1951959400 1951479728
HFS+ magic value at 479675/0/1
HFS+ magic value at 479858/0/1
Mac HFS 479858 1951959585 1951479728
HFS+ magic value at 479860/0/1
HFS+ magic value at 479963/0/1
Mac HFS 479963 1951959690 1951479728
HFS+ magic value at 479965/0/1
HFS+ magic value at 480052/0/1
Mac HFS 480052 1951959779 1951479728
HFS+ magic value at 480054/0/1
HFS+ magic value at 480253/0/1
Mac HFS 480253 1951959980 1951479728
HFS+ magic value at 480255/0/1
HFS+ magic value at 480502/0/1
Mac HFS 480502 1951960229 1951479728
HFS+ magic value at 480504/0/1
HFS+ magic value at 480615/0/1
Mac HFS 480615 1951960342 1951479728
HFS+ magic value at 480617/0/1
HFS+ magic value at 480680/0/1
Mac HFS 480680 1951960407 1951479728
HFS+ magic value at 480682/0/1
HFS+ magic value at 480881/0/1
Mac HFS 480881 1951960608 1951479728
HFS+ magic value at 480883/0/1
HFS+ magic value at 480994/0/1
Mac HFS 480994 1951960721 1951479728
HFS+ magic value at 480996/0/1
HFS+ magic value at 481059/0/1
Mac HFS 481059 1951960786 1951479728
HFS+ magic value at 481061/0/1
HFS+ magic value at 481340/0/1
Mac HFS 481340 1951961067 1951479728
HFS+ magic value at 481342/0/1
HFS+ magic value at 481453/0/1
Mac HFS 481453 1951961180 1951479728
HFS+ magic value at 481455/0/1
