FAT32 USB drive unreadable after mounting on old Windows computer
paolocesari
#1 Post by paolocesari »
Hello everyone,
I have a 32GB USB drive formatted FAT32 usually used on Mac OS.
Yesterday I putted it on old Windows computer to copy a file ad the operation was aborted.
Now the USB drive isn't readable and I always see the terrible message "format drive?" (NO!)
I also tried to create an image backup with "dd", but it seems does't work.
Does anyone have any suggestions? How can I rescue the disk and the datas inside?
Thanks a lot!
This is TestDisk 7.1 log and the main problems are:
  • Partition sector doesn't have the endmark 0xAA55
  • The harddisk (31 GB / 29 GiB) seems too small! (< 31 GB / 29 GiB)
  • Partition can't be recovered
Disk /dev/sdc - 31 GB / 29 GiB - VendorCo ProductCode
Analyse Disk /dev/sdc - 31 GB / 29 GiB - CHS 30000 64 32
FAT32 at 4/1/1
FAT1 : 2784-17775
FAT2 : 17776-32767
start_rootdir : 32768 root cluster : 2
Data : 32768-61439935
sectors : 61439937
cluster_size : 32
no_of_cluster : 1918974 (2 - 1918975)
fat_length 14992 calculated 14992
FAT differs, FAT sectors=0-16/14992
FAT32 at 4/1/1
FAT: cluster=2(0x2), pos=40992
FAT: cluster=7(0x7), pos=41152
file_pread(6,32,buffer,41152(20/6/1)) read err: Partial read
FAT: cluster=8(0x8), pos=41184
FAT: cluster=20(0x14), pos=41568
file_pread(6,32,buffer,41568(20/19/1)) read err: Partial read
FAT: cluster=21(0x15), pos=41600
FAT: cluster=42(0x2a), pos=42272
file_pread(6,32,buffer,42272(20/41/1)) read err: Partial read
FAT: cluster=43(0x2b), pos=42304
FAT: cluster=48(0x30), pos=42464
file_pread(6,32,buffer,42464(20/47/1)) read err: Input/output error
file_pread(6,1,buffer,42464(20/47/1)) read err: Input/output error
FAT: Can't read directory cluster.
     FAT32 LBA                4   1  1 30003  63  1   61439937 [DISK_IMG]
     FAT32, blocksize=16384, 31 GB / 29 GiB
This partition ends after the disk limits. (start=8224, size=61439937, end=61448160, disk end=61440000)
file_pread(6,16,buffer,10272(5/1/1)) read err: Input/output error
file_pread(6,1,buffer,10272(5/1/1)) read err: Input/output error
file_pread(6,16,buffer,10256(5/0/17)) read err: Input/output error
Re: FAT32 USB drive unreadable after mounting on old Windows computer
Do not use dd as it is not suitable for potentially broken storage.
Use ddrescue as described in the manual.
Use a logfile, ddrescue calls it "mapfile", post it here, make a screenshot of the ddrescue command line overview screen.
If ddrescue fails contact a professional recovery service.
