Dear all,
while switching hard disks I accidentally reset the partition type on my data drive to a wrong one and lost access to my files. I am not an expert on file systems so I am unsure about how to further proceed with Testdisk even after reading through a lot of comments and articles.
The drive is a 1TB (and almost fully written) with a lot of folders and small files - from photos to mp3. I've run the first stages of test drive.
I found the deleted partition but am reluctant to rewrite it to a logical one since I got an error "the hard disdks seems to small. Check the harddisk size... The following partitions can't be recovered".
Any advice, whether setting from D to L and write is a good idea in the context?
Thank you so much!
Christian
Mon Dec 6 01:10:05 2021
TestDisk 7.2-WIP, Data Recovery Utility, September 2021
OS: Windows 8 (9200)
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499135623168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=125025255424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=875177181184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000363192320
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 840 EVO 500GB, S/N:S1DHNSAF444336N, FW:EXT0BB6Q
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM024 HN-M101MBB, S/N:S2R8J9HBC28539, FW:2AR10001
Disk \\.\PhysicalDrive3 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD Elements 25A2, S/N:WXS1EB59NFML, FW:1014
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - ST1000LM024 HN-M101MBB
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
test_FAT()
1 * FAT16 >32M 0 4 5 15200 35 3 244189952
sector_size 512
cluster_size 8
reserved 0
fats 0
dir_entries 0
sectors 0
media F8
fat_length 0
secs_track 63
heads 240
hidden 256
total_sect 0
test_FAT()
2 P FAT16 >32M 15200 51 20 121601 25 24 1709330432
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
Partition Table contains two or more Primary DOS FAT partitions
NTFS at 0/4/5
heads/cylinder 240 (NTFS) != 255 (HD)
filesystem size 244190208
mftmirr_lcn 2
HPFS - NTFS 0 4 5 15200 39 7 244190208
NTFS, blocksize=4096, 125 GB / 116 GiB
BAD_RS LBA=1908242784 1552540
FAT16 <32M 118782 158 1 254602 34 4 2181940492
This partition ends after the disk limits. (start=1908242784, size=2181940492, end=4090183275, disk end=1953525168)
BAD_RS LBA=2643882435 4132988
FAT16 <32M 164574 17 55 340879 30 1 2832340591
This partition ends after the disk limits. (start=2643882435, size=2832340591, end=5476223025, disk end=1953525168)
NTFS at 121601/57/56
filesystem size 1953325049
mft_lcn 86993
mftmirr_lcn 2
HPFS - NTFS 12 93 25 121601 57 56 1953325049
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
mft_lcn 86993
mftmirr_lcn 2
NTFS: Can't read MFT
HPFS - NTFS 121601 57 56 243190 22 24 1953325049
This partition ends after the disk limits. (start=1953523711, size=1953325049, end=3906848759, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 2803 GB / 2611 GiB)
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 12 0 1 121601 57 56 1953330932
5 L HPFS - NTFS 12 93 25 121601 57 56 1953325049
Partitions that can't be recovered Topic is solved
Re: Partitions that can't be recovered
I don't know what "test drive" should mean. If you mean "Testdisk" instead, please correct your posting to avoid confusing people reading in thsi forum. Thank you!christianb wrote: 06 Dec 2021, 10:48 Dear all,
Use the "p"-key ("list files") to see if Testdisk shows valid content. You know best how many partitions you had and what their size was. That should determine your choice.
Why don't you use the German forum, by the way?
christianb
Thanks. With trying P on different partitions and then resetting them from D to L worked! Donation underway!
