Im trying recover some videos for my father from SD Card however im troubled.
Qphotorec can find orf,jpg, mov, txt, gz, apple and tif files BUT no mod files.
Is it because Qphotorec interface do not have all options visible than photorec?
or possible something else ?
I did put X to saving mov and mod files separately but did not take X from mov.
QPhotorec can not find MOD files
Re: QPhotorec can not find MOD files
Im trying find mod files for mov files so i could make videos workable again.
Any suggestions?
Any suggestions?
I posted the list of formats to show you that there is no support for "mod" files.
You would need to read chapter twelve of the manual "CREATING CUSTOM SIGNATURE FOR PHOTOREC".
JEfromCanada
I am new on the forum and am asking questions of my own, but I'll refer you to this article on MediaWiki:
https://en.wikipedia.org/wiki/MOD_and_TOD
In short, the article implies that MOD files are equivalent to MPEG-2 files, so if you do need to define your own template for the MOD file format (as suggested by @recuperation), you might want to view the file template for MPEG-2 and use that as a guide.
DISCLAIMER: I am not an expert in anything (other than searching the internet for answers), so please take my advice with more than a grain of salt.
Thanks for posting that information!
The obvious consequence is that MOD files while not be labeled different from other mpeg files when being recovered using Photorec.
Yes i know what is MOD file is and how to remake MOV files with mov+mod file. Problem is when i scan SD card it does not find any. Video have taken with canon powershot D-10. Does anyone know any reason behind it? I have not used SD card after noticed I removed wrong files.
You did not provide any documentation in your case.
I can only guess that your card is broken and recommend you consulting a professional recovery lab.
