Recovering partition.
SyncroScales
#1 Post by SyncroScales »
testdisk-7.1WIP
I have a hard-disk that was formatted or lost it's partition. I looked for the partition and found what seems to be the NTFS partition and the smaller partition in-front of it, maybe for boot. The choice I have after selecting the NTFS partition is
Write partition table, confirm? <Y/N>.
Will this write onto the hard-disk? Or is the next option where I can put it? I wanted to put it onto an external hdd. Maybe use photorec_win and qphotorec_win?
I don't want to write over the hard-disk I need to data recover. Just in case I need to perform further analysis/scans/etc.
Hard-disk being scanned is 500GB, the external hard-disk is 1TB (empty).
Not sure which version of Windows the damaged hard-disk was formatted from and used for. Was apparently not re-formatted.
Hard-disk is recognized in Disk Management and Device Manager. No I/O errors or lags, crashing, etc. Hard-disk seems to be fine, with no partition visible.
Re: Recovering partition.
SyncroScales wrote: 13 Jan 2022, 03:10 Hi,
testdisk-7.1WIP
Yes, this is a repair function.
A partition table is specific for a specific drive. There is no use in writing the partition table elsewhere.
As you loose file metadata information you should do this if writing the partition table fails.
Duplicate your hard drive using ddrescue as described in the manual. When having a copy of your broken drive you don't have to worry about write operations.
SyncroScales
#3 Post by SyncroScales »
Thanks for the reply.
So I repaired the drive. There was only one * bootable and P - Primary partition. I wrote the partition table. I restarted the computer. In Computer I see two drive letters that have 100MB (NTFS) and 565MB (NTFS). But the data section in the middle is not there. The file system and disk seem to be Windows 7 or 8.x.
In Windows - Disk Management shows the disk with 3 partitions. 1. System Reserved (Drive letter), 100MB (NTFS), Healthy (Active, Primary Partition), 2. 465.11 GB, Unallocated and 3. (Drive letter), 565 MB (NTFS), Healthy (Primary Partition).
In testdisk - there are only 2 partitions. I think the partition on the end is the back-up for the first partition.
I was in this tutorial https://www.cgsecurity.org/wiki/TestDisk_Step_By_Step - I checked NTFS Boot sector recovery, and for both partitions, they are OK.
Boot Sector
Status: OK
Back Up Boot Sector
Status: OK
Sectors Are Identical
In:
[Advanced]
I tried to [Repair MFT], MFT and MFT mirror match perfectly.
File Undelete - No deleted Files Found.
[Rebuild BS] - I don't think I need to do this?
I am using QPhotoRec right now. I really don't want to re-format and then attempt commercial software to find the folder structure and files. Do I have to do that?
SyncroScales wrote: 13 Jan 2022, 12:29 I am using QPhotoRec right now. I really don't want to re-format and then attempt commercial software to find the folder structure and files. Do I have to do that?
Formating means deleting information. You only do this if you give up your data and want to use your partition/drive again. You rather sound that you want to rescue your data, though. => NO FORMATING!
When being unhappy with the result of QPhotoRec try out commercial recovery software.
