CMOS reset killed my Intel RST Raid 5 (9TB) Topic is solved
Paxinox
#1 Post by Paxinox »
Hey guys,
Ive been digging through google and youtube for help here, until I was told about TestDisk and you guys.
My Asrock X99 OC motherboard experienced a CMOS reset, and it decided to change my RAID config to AHCI during Windows 10 bootup.
To my surprise my Raid 5 was gone, and after troubleshooting, rebooted into bios, changed back to RAID, booted up WIndows 10, but to no avail.
It reported back as failed raid array.
I followed instructions for using TestDisk to recover my raid partition configuration,
1) Deleting Raid Array
2) Creating Identical Array
3) Restarting Computer
4) Letting it initialize (even though that scared the living hell out of me)
Now, Ive ran TestDisk, let it sit for 8 hours, and its still running. Based on how it works through 1 sector per second, the remaining time is roughly 260 days.
What can I do here? I havent formatter the disks, but I let them reinitialize TWO times. (First time I recreated the array, then deleted it, because I thought initializing was going to make the partition unrecoverable)
Does initializing harm the partitions in any way?
Is there something else I can try? I hope my partition can be saved, as any recovery attempts doesnt actually show the important folders (only about 50gig, the rest I have backup of).
I am willing to donate a nice sum to the CGSecurity Team if you can help me out!
Update! It found some more:
Disk \\.\PhysicalDrive2 - 10001 GB / 9315 GiB - CHS 1216005 255 63
Analyse cylinder 269249/1216004: 22%
Linux filesys. data        10240 3907037183 3907026944
Linux filesys. data   3907666086 3911776287    4110201 [M-: ]x~B~MM-*^A6^]M-(; U~Y]
Warning: number of heads/cylinder mismatches 2 (FAT) != 255 (HD)
Warning: number of sectors per track mismatches 18 (FAT) != 63 (HD)
EFI System            4324719664 4324722543       2880 [EFI System Partition] [EFISECTOR]
Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD)
Warning: number of sectors per track mismatches 2 (NTFS) != 63 (HD)
MS Data               4324723483 4324729656       6174
MS Data               4324729656 4324735829       6174 [Boot]
Re: CMOS reset killed my Intel RST Raid 5 (9TB)
Paxinox wrote: 17 Jan 2022, 16:18 I am willing to donate a nice sum to the CGSecurity Team if you can help me out!
For professional contract-based logical recovery services you might contact the creator of this site.
How do you like this picture?
kisspng-royalty-free-carrot-clip-art-carrots-clipart-5aee8f5cdbe923.0814718515255837089008.png
kisspng-royalty-free-carrot-clip-art-carrots-clipart-5aee8f5cdbe923.0814718515255837089008.png (352.19 KiB) Viewed 6126 times
source:
https://de.cleanpng.com/png-w9vdl1
#3 Post by cgrenier »
Try PhotoRec for a few minutes. Does it recover valid files ?
If it recovers small useless files, it's because the Raid 5 hasn't the same settings than previously.
Try TestDisk only once the Raid5 is correctly configured.
Paxinox
#4 Post by Paxinox »
cgrenier wrote: 17 Jan 2022, 20:45 Try PhotoRec for a few minutes. Does it recover valid files ?
I tried what you suggested,
and recovered a 1,1gig videofile which works perfectly in 1080P quality, no corruption or CRC-issues.
I have configured the RAID array identically to the original array,
"Volume_0000
Raid5(Parity)
128KB
9.0TB
Failed"
This was the raid array info in Intel RST through UEFI BIOS.
The only difference I can think of, is that I created this RAID 5 volume through Windows Intel RST, not the bios.
But that shouldnt matter right? The order of the disks is identical.
Got any idea what I should do?
Im fairly certain Testdisk can fix this array
Update:
Its now ran for approx 28 hours:
Any suggestions?
#5 Post by cgrenier »
Which OS did you use to access your data ?
How many partitions do you had ? What was the filesystem ? What was the partition size ?
Paxinox
#6 Post by Paxinox »
Okey, good news, saved the raid! :D :D
I stopped the search, restarted it and chose deep search, then stopping after about 5 minutes, then chose partition "RAID 5", (by using right arrow), pushed P for listing files and it showed everything without damages.
I copied out the most important, (just in case),
Then I chose the Raid 5 partition (by using right arrow), then pushed enter and then write.
Restarted computer, and VOILA, the partition shows in explorer.
All files there, no CRC, no issues whatsoever.
This tool is the best recovery tool Ive ever seen, Ive been in the computer business for 20 years, and my hat is off for you Christophe Grenier!!
