Rebuild BS FAT16 - Can't find cluster size Topic is solved
jeremyp52
#1 Post by jeremyp52 »
Trying to restore Boot sector for hard drive pulled out of vintage 386 system.
Have consulted wiki for FAT boot sector repair - https://www.cgsecurity.org/wiki/Advanced_FAT_Repair
Began process, it identified the drive as FAT : 32 after doing a FAT table search, then began a subdirectory search, which ran all night. It informed me Can't find cluster size. Here is an example of what the main Boot menu looks like:
Disk \\.\PhysicalDrive1 - 2559 MB / 2441 MiB - CHS 311 255 63
1 P FAT16 LBA 0 2 3 234 152 46 3768704
Bad
Here is an example of when it is searching for directories. Note how it identifies this as FAT : 32:
FAT : 32
Search subdirectory 1024/3768704 3
And, ultimately when it fails:
Here is a copy of the log:
Tue Jan 25 16:17:26 2022
TestDisk 7.2-WIP, Data Recovery Utility, September 2021
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1024215482368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2559836160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1004189761024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1929576448
Disk \\.\PhysicalDrive0 - 1024 GB / 953 GiB - CHS 124520 255 63, sector size=512 - Intel Raid 0 Volume, S/N:ASUS_OS, FW:1.0.00
Disk \\.\PhysicalDrive1 - 2559 MB / 2441 MiB - CHS 311 255 63, sector size=512 - DW CCA23 05H0, S/N:20131013
Disk \\.\PhysicalDrive1 - 2559 MB / 2441 MiB - DW CCA23 05H0
Geometry from i386 MBR: head=153 sector=46
test_FAT()
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
fat1x_boot_sector
Bad
rebuild_FAT_BS p_fat12 0, p_fat16 1, p_fat32 1
fat_find_type(max_offset=29507, p_fat12=0, p_fat16=1, p_fat32=1, debug=1, dump_ind=0)
FAT16 at 5681(0/92/14), nbr=1
FAT32 at 11460(0/183/60), nbr=18
first_fat 11460, second_fat 5681
FAT : 32, reserved=0, fat_length=0
find_sectors_per_cluster skip_sectors=172 (skip_offset=88064)
sector 496, cluster 2
sector 688, cluster 5
sector 752, cluster 6
find_sectors_per_cluster_aux
sectors_per_cluster=64 offset=496 nbr=2 FAT : 16
fat1x_boot_sector
Bad
Re: Rebuild BS FAT16 - Can't find cluster size
If Testdisk fails to propose a valid boot sector you should contact a professional recovery company.
This is my advice because you are not talking about trying to perform data recovery but want to logically repair your drive.
jeremyp52
#3 Post by jeremyp52 »
recuperation wrote: 25 Jan 2022, 23:00 If Testdisk fails to propose a valid boot sector you should contact a professional recovery company.
Thank you!
