Recovery WD Caviar black 1To Topic is solved
GuillaumeC
#1 Post by GuillaumeC »
Hi !
I lost my /home partition :oops:
Please help !
I lost 2 days by trying to fix it.
I have 3 primary partitions : 2 partitions in ext4 ( / and /home) and 1 for the swap
Here is my results before a quick search :
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
 1 * Linux                    0  32 33  4863  15 16   78123008
 2 P Linux Swap            4863  15 17  5835 158 19   15624192
 3 P Linux                 5835 158 20 121601  57 56 1859774464
and after a quick search
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121602 255 63
The harddisk (1000 GB / 931 GiB) seems too small! (< 2446 GB / 2278 GiB)
>  FAT32                223314 138  4 297488 227 35 1191610949
then
>* Linux                    0  32 33  4862 205 15   78118912
 P Linux Swap            4863  15 17  5835 158  3   15624176
what should I do ?
thanks for your help.
Re: Recovery WD Caviar black 1To
Run TestDisk, Advanced, select your /home partition, choose Superblock and use the given values to run fsck.ext4
GuillaumeC
#3 Post by GuillaumeC »
Thx. It works !!!
