Recovering Partition
runninghamster
#1 Post by runninghamster »
I have a drive that was accidentally turned into a dynamic disk whilst trying to extend the main partition on the drive. This caused Windows to recognise the drive as unreadable and my data lost.
I have tried TestDisk and I can see the main partition of the drive, however I encounter an error exclaiming that the partition is unrecoverable. I am attaching the TestDisk log below, any help would be appreciated.
I did also try another tool, GetDataBack which seems to find the partition & and I am able to view my files. Recovering the partition itself using TestDisk would be preferable to manually copying the files over using that program.
Thank you very much.
TestDisk: 7.2 WIP
Drive: ST1000DM003-1ER162
Partition: HPFS - NTFS 44 190 19 121645 118 9 1953515520
Thu Jan 27 23:08:10 2022
TestDisk 7.2-WIP, Data Recovery Utility, September 2021
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=240065183744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239941451776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
Disk \\.\PhysicalDrive0 - 240 GB / 223 GiB - CHS 29186 255 63, sector size=512 - WDC WDS240G2G0A-00JH30, S/N:192293800120, FW:UF450000
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1ER162, S/N:Z4Y0MTRE, FW:CC43
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MQ01ABD100, S/N:573FTN0BT, FW:AX0P3D
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - ST1000DM003-1ER162
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
filesystem size           716800
sectors_per_cluster       8
mft_lcn                   29866
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33    44 190 18     716800 [System Reserved]
     NTFS, blocksize=4096, 367 MB / 350 MiB
NTFS at 44/190/19
filesystem size           1953515520
mftmirr_lcn               2
This partition ends after the disk limits. (start=718848, size=1953515520, end=1954234367, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 1000 GB / 931 GiB)
   * HPFS - NTFS              0  32 33    44 190 18     716800 [System Reserved]
NTFS at 0/32/33
mft_lcn                   29866
mftmirr_lcn               2
NTFS at 44/190/18
mft_lcn                   29866
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 367 MB / 350 MiB
NTFS at 44/190/19
mftmirr_lcn               2
Re: Recovering Partition
https://www.hdat2.com/files/disk_probe.pdf
might help. Use at your own risk. Every disk editor that is able to manipulate the drive should be able to do the job.
Haven't tried that recipe before.
You can test the procedure with a second drive whose content had been backed up.
