heic support?
kmeleon
heic support?
#1 Post by kmeleon »
Hi, as per wiki, heic should be supported, but I cannot find option to tick em. I was able to rescue jpegs, but I'd love to get the new heices too. I'm on linux though, if that makes any difference.
PhotoRec 7.2-WIP, Data Recovery Utility, February 2022
PhotoRec will try to locate the following files
    Previous
 [ ] fos  Fallout 4 Savegame
 [ ] fp5  File Maker Pro
 [ ] fp7  File Maker Pro
 [ ] freeway Freeway 5 Pro
 [ ] frm  Pro/ENGINEER Drawing Form
 [ ] fs   Zope
 [ ] fwd  FRWD Sports Computer
 [ ] gam  Games Factory
 [ ] gct  XFI Electronic Fuel Injection Systems
 [ ] gho  Ghost
 [ ] gi   Roxio Creator
 [ ] gif  Graphic Interchange Format
 [ ] gm*  Game Maker (4.3 - 8.1)
 [ ] gp2  Gobe Productive Document
 [ ] gp5  Guitar Pro 4 & 5
 [ ] gpg  OpenPGP/GPG (Partial support)
 [ ] gpx  Guitar Pro 6
 [ ] gsm  Group Speciale Mobile GSM 06.10
>[ ] gz   gzip compressed data
 [ ] hdf  Hierarchical Data Format 4
 [ ] hdf  Hierarchical Data Format 5
 [ ] hdr  InstallShield
 [ ] hds  Parallels disk image
 [ ] hfsp HFS+/HFSX
 [ ] hm   HyperMesh, structural analysis software
 [ ] hr9  Heredis - Genealogy
 [ ] http HTTP Cache
 [ ] ibd  InnoDB database file
 [ ] icc  Color profiles
 [ ] icns Apple Icon Image
 [ ] ico  Windows Icon
 [ ] idx  RT60
    Next
Press s for default selection, b to save the settings
>[  Quit  ]
                              Return to main menu
Thank you.
Re: heic support?
The extension "heic" is part of the "mov" family. You can verify that by placing a heic-file on a USB stick, deleting it and let Photorec search without having "mov" checked once, check "mov" and let Photorec search again.
kmeleon
Re: heic support?
#3 Post by kmeleon »
Hello and thank you very much for reply and valuable info. I'll tick the mov then. Actually I have a dead external hdd, which I have already ddrescued onto another disk, so now I can verify it on real data :)
