Ran bootrec commands on windows 10 laptop and now it shows whole 1tb (931gb) as free
bkd8
#1 Post by bkd8 »
Greetings,
(with heavy heart :cry: )
Problem In Short: After an update, Windows 10 home single language edition showed “Bad System Config Info” error (BSOD). In a state of panic I googled this so called “stop code” and stumbled on to the following commands, which I ran (like I would die if I don’t):
bootrec /fixmbr
bootrec /fixboot
bcdedit /export c:\bcdbakcup
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
Now, my whole 1tb (931gb) hdd is shown empty by diskpart. See disk 0 in the following image. Though, testdisk does show all deleted or lost partitions with labels (see third image), which is awesome. Only problem is i can't figure out how to get it back. Please help.
My attempts with testdisk so far:
1. I tried Analyze option but its taking 10min or more for 1%, i stopped at 29% .
2. Then i tried Advanced options, where i learn that data in all partitions are good, except EFI Partition which is corrupt.
It would be great if someone could help me in putting it all together like it was before, that is if possible. If not please let me know. Any help is appreciated. Thank you.
Re: Ran bootrec commands on windows 10 laptop and now it shows whole 1tb (931gb) as free
I apologize, I can't help you with repairing your broken installation. I have no experience with Windows 10 repairs.
You said that Testdisk took 10 min for 1% out of 1000GB. That translates into 1GB/min or 16,7 MB / sec. That seems to be to slow even for a 2,5'' drive with 5400 rpm.
The same advice I gave here
viewtopic.php?p=35630#p35630
applies for you as well.
After duplicating you can run Testdisk again and use the "p"-key "list files" to examine the remains of your drive content and duplicate your unaccessible data to another drive.
bkd8
#3 Post by bkd8 »
Thank you for replying. I Will try the advice mentioned in the link.
That being said, can you give any hints as to what might have gone wrong?
Partitions and Data are there, except ESP, is there any way to just build ESP with partition table information?
bkd8 wrote: 13 Feb 2022, 18:23 That being said, can you give any hints as to what might have gone wrong?
No. Read here, I just added Point 17:
viewtopic.php?p=35633#p35633
Your Windows repair installation should do that for you.
