Error when "List and copy files"
Lelle99
#1 Post by Lelle99 »
I really messed up my external ssd.
Disk management says raw.
When trying to "List and copy files", nothing recovered, only error.
Any chance that I can recover any files?
Stuff from the log:
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - PNY PNY PRO ELITE PS
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121599 255 63
1 * HPFS - NTFS 0 32 33 121599 112 49 1953492992
exFAT, blocksize=262144, 1000 GB / 931 GiB
exfat_ucstoutf8: iconv failed Invalid or incomplete multibyte or wide character
Br
Re: Error when "List and copy files"
Try to duplicate your possibly broken drive as described in the manual.
Before doing so it is always revealing what your drive SMART parameters tell you:
viewtopic.php?f=5&t=10910
Lelle99
#3 Post by Lelle99 »
Hi
When you say "duplicate" what exactly do you mean and in which manual?
Here https://www.cgsecurity.org/testdisk.pdf ?
You mean I should create a disk image?
This is report from Smartmontools. Please comment if it contains something useful
Device Model: PNY PRO ELITE PSSD
Firmware Version: CS206P13
User Capacity: 500 107 862 016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: M.2
TRIM Command: Available
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
been run.
data collection: (65535) seconds.
capabilities: (0x79) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 30) minutes.
Conveyance self-test routine
recommended polling time: ( 6) minutes.
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 4258
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 21
168 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 0
170 Unknown_Attribute 0x0003 100 100 010 Pre-fail Always - 151
173 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 65538
192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 18
194 Temperature_Celsius 0x0023 067 067 000 Pre-fail Always - 33 (Min/Max 33/33)
218 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
231 Unknown_SSD_Attribute 0x0013 100 100 000 Pre-fail Always - 99
241 Total_LBAs_Written 0x0012 100 100 000 Old_age Always - 560
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Lelle99 wrote: 16 Feb 2022, 11:45 Hi
Yes.
Could you update your smartmontools-database and repost the file again?
Hopefully that will label the unknown attributes!
Lelle99
#5 Post by Lelle99 »
Hi
I found a script: update-smart-drivedb.ps1
This is what I get after running the script and then create report:
Device is: Not in smartctl database 7.3/5301
I will try to find time today to do the image
Lelle99
#6 Post by Lelle99 »
Hi
I couldn't find anything in the manual about how to create an image.
But I found it in the application.
Its been working 8h now and has reached 0.7%. This is of course taking too long.
Should we work on the original disk instead?
What is the next step?
Br
Lelle99
#7 Post by Lelle99 »
Hi
Image creation failed.
Image file is 50 MB.
The log is 8 MB full of this:
file_win32_pread(536,1,buffer,4776192(297/77/37)) read err: read after end of file
Please suggest next step
#8 Post by recuperation »
Lelle99 wrote: 17 Feb 2022, 08:08 Hi
May I kindly ask you to really read the manual? :roll:
Seriously reading the table of contents should set you on the right track.
It is kind of sad being faced with this type of problems.
The function in Testdisk is not suitable for your purpose and has stressed your drive for an additional 8 hours with virtually no outcome.
You should read the manual instead and it is not required to read it entirely.
Lelle99
#9 Post by Lelle99 »
Hi
Yes you mean ddrescue
I started it and just let it be.
Checking it now. It is stuck:
Current rate: 0 B/s
Non-tried: 1000 GB
Bad sector: 512 B
Time since last successful reads: 3d etc
The manual says "If the main boot sector is damaged, the filesystem is listed as raw or unreadable"
So next step is "7.4 Repairing FAT32, exFAT and NTFS boot sector using TestDisk",
Is this correct?
Br
#10 Post by recuperation »
Lelle99 wrote: 21 Feb 2022, 16:04 Hi
Current rate: 0 B/s
Non-tried: 1000 GB
Bad sector: 512 B
Is this correct?
Br
No, this is not the next step.
Did you run ddrescue with admin rights?
ddrescue tries to jump over defective areas. If it didn't recover a single sector you should contact a professional recovery service.
Unfortunately you did not post a screenshot of the overview screen of ddrescue.
