Recovery of deleted partition / formatted drive that was using Bitlocker
ddhddrk1
#1 Post by ddhddrk1 »
Hello!
I unfortunately just had a mishap. I was installing Windows on a new PC, and mistakingly selected the wrong drive to delete a partition from.
I noticed my error almost immediately, so luckily I did not install windows over the top of it.
This is not my screenshot, but it IS the option I used to delete the drive.
This HDD was setup as a full-drive encrypted Bitlocker drive that automatically unlocks upon system login
I have 2 recovery keys (not sure which one is the correct drive).
Is there any way to get this back, or is TeskDisk not really the right tool for what I'm trying to do?
Before I "go down the rabbit hole" I might be trying to do something it's not capable of.
I first did a Quick Scan with PC Intel, and after about an hour and a half it finished with "The following partition can't be recovered / Filesystem damaged".
I will update this post in the morning with my log file.
Thank you!
Re: Recovery of deleted partition / formatted drive that was using Bitlocker
Could you rewrite your description avoiding the words "drive" and "full-drive"? "Drive" has two meanings. It is referring to a complete disk but is as well used to refer to partitions like the "C-drive" which is correctly speaking a partition on a disk. See how the term is used on your picture!
Thank you.
satyricon
#3 Post by satyricon »
I was in exaclty the same situation. I was not sucessfull with testdisk (great tool, thx) - even after hours of scanning on a 8 TB drive.
In the end I was SUCCESSFULL with "Disk Genius" - found the lost partition withing seconds - entered the bitlocker key, recovered within 1 minute. See also https://www.reddit.com/r/windows/commen ... partition/ <-- here I found the initial hint for this tool.
br, christian
