Photorec
conib00
Photorec
#1 Post by conib00 »
Hello I am running Photorec against a 4Tb NTFS disk to retrieve JPG and MPG with file option JPG an MPG on Ubuntu 20.04.
At a disk with no problems I just want to retrieve deleted pictures
Now I see on
date 2022-02-18 Pass 1 - Reading sector 444548496/2930272002, 10596 files found. Elapsed time 140h estimated time to completion 787h
date 2022-02-21 Pass 1 - Reading sector 413585288/2930272002, 12038 files found. Elapsed time 212h estimated time to completion 1293h
date 2022-02-23 Pass 1 - Reading sector 476622304/2930272002, 12954 files found. Elapsed time 260h estimated time to completion 1338h
Why is it that the Reading sector goes up and down? and time to completion goes up so much??
And reading sector also strange readings.
Where/when does this end??
Regards Bas.
Re: Photorec
conib00 wrote: 23 Feb 2022, 13:49 Hello I am running Photorec against a 4Tb NTFS disk to retrieve JPG and MPG with file option JPG an MPG on Ubuntu 20.04.
And what is your Photorec version?
Now I see on
Broken sectors will increase recovery time. Testdisk is not supposed to work on such broken drives. Check the health of your drive and depending on the outcome you will be better off duplicating your drive using ddrescue. Are you recovering your stuff on a separate disk?
Please ask a clairvoyant.
conib00
Re: Photorec
#3 Post by conib00 »
recuperation wrote: 23 Feb 2022, 16:27 And what is your Photorec version?
The version I use = "PhotoRec 7.1, Data Recovery Utility, July 2019.
Yes I am using a separate disk for the "recup_dir.##" files
I am using a 4Tb disk (USB) and had no problems with reading and writing in the past.
Re: Photorec
Please try again using the most recent Photorec version "7.2 WIP".
To get a quick overview on possible health issues of your drive post your smartmontools log file:
viewtopic.php?f=5&t=10910
conib00
Re: Photorec
#5 Post by conib00 »
recuperation wrote: 24 Feb 2022, 13:57 Please try again using the most recent Photorec version "7.2 WIP".
see attachments
samsungschijf4.txt
(733 Bytes) Downloaded 1129 times
samsungschijf.txt
(759 Bytes) Downloaded 869 times
Re: Photorec
#6 Post by recuperation »
I have never seen such an empty SMART report.
You could try to duplicate the drive using ddrescue. By looking at the ddrescue command prompt style you will quickly see if ddrescue works or if it hangs on certain sectors.
But I guess you will probably need professional assistance.
conib00
Re: Photorec
#7 Post by conib00 »
recuperation wrote: 25 Feb 2022, 00:50 I have never seen such an empty SMART report.
I think this report is better
samsungschijf.txt
(5.04 KiB) Downloaded 930 times
