Lost Partitions (No endmark 0xAA55) and Photorec Finds Nothing
databoy2k
#1 Post by databoy2k »
Hey All:
I'd love some tips on where to go from here. My drive is a fairly new Seagate 1tb drive, but for whatever reason it has completely lost its way. The drive has a number of music files, legally purchased from back when that was a thing, and some jpeg images of album art. I can't remember if the drive was formatted NTFS or ext3, but I'm fairly sure that it was all one partition.
I did both a quick and deep search with testdisk, and even tried to "force" a partition onto the drive; I can't seem to get partitions to stick. Then I ran Photorec on the default settings on the drive and nothing was recovered.
Testdisk.log (truncated to remove irrelevant drives):
Mon Mar 21 11:59:00 2022
TestDisk 7.2-WIP, Data Recovery Utility, February 2022
OS: Windows 8 (9200)
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM048-2E7172, S/N:ZDELKFKX, FW:0001
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - ST1000LM048-2E7172
Analyse Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63
Change partition type:
     HPFS - NTFS              0   0  1 121600 254 63 1953520065
     Unknown                  0   0  1 121600 254 63 1953520065
     ext3                     0   0  1 121600 254 63 1953520065
Store new MBR code
PhotoRec report.xml:
<dfxml xmloutputversion="1.0">
<metadata xmlns="http://www.forensicswiki.org/wiki/Category:Digital_Forensics_XML" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:dc="http://purl.org/dc/elements/1.1/">
<dc:type>Carve Report</dc:type>
</metadata>
<creator>
<package>PhotoRec</package>
<version>7.2-WIP</version>
<build_environment>
<compiler>GCC 11.2, Cygwin32 3001.4</compiler>
<library name="libext2fs" version="1.45.3"/>
<library name="libewf" version="20140608"/>
<library name="libjpeg" version="libjpeg-turbo-1.5.3"/>
<library name="libntfs" version="10:0:0"/>
<library name="zlib" version="1.2.11"/>
</build_environment>
<execution_environment>
<os_sysname>Windows</os_sysname>
<os_release>Windows 8 (9200)</os_release>
<os_version>Windows 8 (9200)</os_version>
<host>WTM-Dsktp</host>
<arch>i686</arch>
<uid>197611</uid>
<start_time>2022-03-21T20:01:24-0600</start_time>
</execution_environment>
</creator>
<source>
<image_filename>\\.\PhysicalDrive0</image_filename>
<sectorsize>512</sectorsize>
<device_model>ST1000LM048-2E7172</device_model>
<image_size>1000204886016</image_size>
<volume>
<byte_runs>
<byte_run offset="0" img_offset="0" len="1000204886016"/>
</byte_runs>
</volume>
</source>
<configuration> </configuration>
</dfxml>
Any thoughts on where I go from here? Thanks a lot.
Re: Lost Partitions (No endmark 0xAA55) and Photorec Finds Nothing
You messed up your drive by trying to change partition types and writing artificial partitions instead of doing a standard search procedure that is described on this site and is reflects in hundreds of support cases in this forum.
I have no idea what to do now.
databoy2k
#3 Post by databoy2k »
Thanks for the look. Unfortunately, this is how the drive started. First thing I did was the Quick-Search / Deep Search method. I assume that the log shows that. When neither even turned up a single partition, I tried to add partitions by guessing.
Is that maybe the right route to go down? Use Testdisk to write an MBR and then create a partition at sector 2048? That's where the other drives that I've recovered always started their partitions.
Is your drive an external or an internal one - maybe removed from its housing?
Check your drive's health:
viewtopic.php?f=5&t=10910
databoy2k
#5 Post by databoy2k »
smartctl -a /dev/sda
smartctl 7.3 2022-02-28 r5338 [x86_64-w64-mingw32-w10-21H2] (sf-7.3-1)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate Barracuda 2.5 5400
Device Model:     ST1000LM048-2E7172
Serial Number:    ZDELKFKX
LU WWN Device Id: 5 000c50 0c81f6554
Firmware Version: 0001
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
TRIM Command:     Available
Device is:        In smartctl database 7.3/5319
ATA Version is:   ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Mar 22 14:53:42 2022 MST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(    0) seconds.
capabilities: 			 (0x71) SMART execute Offline immediate.
					No Auto Offline data collection support.
					command.
					No Offline surface scan supported.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 ( 165) minutes.
Conveyance self-test routine
recommended polling time: 	 (   2) minutes.
SCT capabilities: 	       (0x3035)	SCT Status supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   083   066   006    Pre-fail  Always       -       179365846
  3 Spin_Up_Time            0x0003   099   099   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       14
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   067   060   045    Pre-fail  Always       -       5528085
  9 Power_On_Hours          0x0032   090   090   000    Old_age   Always       -       9575 (74 54 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       8
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   074   052   040    Old_age   Always       -       26 (Min/Max 22/39)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       2
193 Load_Cycle_Count        0x0032   067   067   000    Old_age   Always       -       67252
194 Temperature_Celsius     0x0022   026   048   000    Old_age   Always       -       26 (0 21 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       128 (206 237 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       0
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       6355735576
254 Free_Fall_Sensor        0x0032   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
#6 Post by recuperation »
I don't see typical errors.
I can't judge the figures for raw read error rate and seek error rate.
Your load cycle rate after one year of operation appears to high for me. The drive should run much longer before falling asleep. This is an issue that you research for yourself.
You did not answer my other question.
databoy2k
#7 Post by databoy2k »
Sorry; the drive is purely internal. It was bought as an internal drive (never removed from its housing).
#8 Post by recuperation »
Use Testdisk the standard way and provide the log file. Your log file looks kind of unusual and seems only documenting your way of manipulating the disk.
databoy2k
#9 Post by databoy2k »
Thu Mar 24 08:54:47 2022
Store new MBR code
#10 Post by recuperation »
Does Photorec find anything?
