As it was described already above Photorec doesn't see my 1T HDD on my iMac 2017 and shows only MacOs SSD partition. Really hoping on your help guys, thank in advance.
I have installed the brew and the program itself through it as well as I have the admin rights, but maybe I have done something wrong idk.
PhotoRec 7.1, Data Recovery Utility, July 2019
PhotoRec is free software, and
>Disk /dev/disk0 - 28 GB / 26 GiB (RO)
Disk /dev/rdisk0 - 28 GB / 26 GiB (RO)
>[Proceed ] [ Quit ]
Note:
Disk capacity must be correctly detected for a successful recovery.
If a disk listed above has an incorrect size, check HD jumper settings and BIOS
Photorec doesn't see my HDD and shows only MacOs partition.
Re: Photorec doesn't see my HDD and shows only MacOs partition.
Does your Mac see the hard disk drive as a device at least?
How does Testdisk and Photorec react when connecting your drive to a Windows machine?
Any results?
Any results?
I don't have any idea actually, because this actual hdd is embedded in the computer itself and I can't remove it without taking off the screen, there is an option to emulate this drive in so called "target disk mode" which actually just gonna convert a hdd to the basic storage drive, accessible through the thunderbolt cable which connected to another computer.
I dont know what "idk" means.fast666 wrote: 29 Mar 2022, 09:54 As it was described already above Photorec doesn't see my 1T HDD on my iMac 2017 and shows only MacOs SSD partition. Really hoping on your help guys, thank in advance.
>[Proceed ] [ Quit ]
Note:
I don't know why your disk size is not recognized properly and have no idea what to do know.
