"download failed" Topic is solved
ts666
"download failed"
#1 Post by ts666 »
Hi.
Can't find anything on this in the (English) forum. I get download failed no matter which of the windows files I choose (also tried the ones for v 7.1). Also tried both Firefox and Chrome.
Is this a temporary error or have the files been removed?
Thanks in advance.
Re: "download failed"
I just downloaded the windows version without having any problems.
Please check if your download target location contains free space. Try downloading something else.
Are you downloading this file from a computer of your employer who does not want you to download executables?
Your case description is not sufficient: You do not outline from which location you try to download Testdisk.
ts666
#3 Post by ts666 »
I have manual target selection, also tried in both Linux and Win (forgot to mention, sorry), so that can't definitely have been it..tried again tonight, and it worked right away, so some temp glitch I presume..thanks anyway...
