WD external not showing up on Testdisk but in Dev. Manager
vire
#1 Post by vire »
I have a 500GB external WD USB hard disk. Because it was not connected properly into USB port, suddenly it went blank.
Model: WD My Passport 0730
Type: Local Disk
File system: RAW
Used space/ free space: 0
I'm sure It was not encrypted because I disabled it.
I tried running TestDisk but the disk doesn't appear because it couldn't find the correct size.
The disk showing up in Device Manager but not in the Disk Management Console.
Here's the log from Test Disk 6.14
Tue Aug 28 11:18:06 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
OS: Windows XP SP2
Compilation date: 2012-08-14T11:59:29
filewin32_getfilesize(/dev/sdb) GetFileSize err Incorrect function.
filewin32_setfilepointer(/dev/sdb) SetFilePointer err Incorrect function.
Warning: can't get size for Disk /dev/sdb - 0 B - 1 sectors, sector size=512 - WD My Passport 0730
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=10487199744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=10487199744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=26213935104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=246659664384
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - HITACHI HTS543232A7A384, FW:ES2ZB70B
Is there any way to recover my file?
Any help would be appreciated.
Thank you.
Re: WD external not showing up on Testdisk but in Dev. Manag
Unfortunately it's an hardware problem, to recover your data, you will have to contact a data recovery company.
