Forum searching
intrac
Forum searching
#1 Post by intrac »
This is a new user post/observation, as opposed to a question. I have noticed that there is a great deal of history in previous posts, but the search feature doesn't seem to display more than a single page of results. Before posting a question though, it seems very desirable to see if anyone else has ever had the same question. Fortunately, I found a good way of using Google to find a whole bunch of results, and I just wanted to share it. In addition to the desired search terms, you can add in the following "site:cgsecurity.org". For example, the search for "testdisk partition table type intel efi site:cgsecurity.org" resulted in over 5k results.
Once I learn a bit more, hopefully I can follow-up with an educated question. Thanks.
Re: Forum searching
Indeed, the google search engine is a powerful one and it's worth using it the way you described - not only with www.cgsecurity.org.
