Can't access the partition I added in testdisk.
Iqbroly
#1 Post by Iqbroly »
I had deleted a partition on my drive but successfully got it back thanks to testdisk. But when I changed the letter D(eleted) to P(rimary) for the deleted partition, my other partition was showing D(eleted) but I didn't care and write the table, restarted my pc and successfully backed up my previously deleted partition. I also used photorec on it before to recover some files. Now my other partition is missing and I can't find it in quick search or deep search.
Thu Apr 14 10:14:59 2022
OS: Linux, kernel 5.15.0-kali3-686-pae (#1 SMP Debian 5.15.15-2kali1 (2022-01-31)) i686
Compiler: GCC 10.3
ext2fs lib: 1.46.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.2
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
/dev/sdb: size       976773168 sectors
/dev/sdb: user_max   976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco        976773168 sectors
Warning: can't get size for Disk /dev/loop1 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop2 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop3 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop4 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop5 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500VT000-1DK142, S/N:WBY7WM10, FW:0001SDC1
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HGST HTS545050A7E380, S/N:TEA55B3Q39H33W, FW:GG2ZBD90
Disk /dev/sdc - 15 GB / 14 GiB - CHS 14782 64 32, sector size=512 - TOSHIBA TransMemory, FW:1.00
Disk /dev/loop0 - 2772 MB / 2644 MiB - 5415400 sectors (RO), sector size=512
Disk /dev/sda - 500 GB / 465 GiB - ST500VT000-1DK142
Partition table type: EFI GPT
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976773167 (expected 976773167)
hdr_lba_start=34
hdr_lba_end=976773134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                     2048    1085439    1083392
 2 P EFI System               1085440    1290239     204800 [EFI System Partition]
 3 P MS Data                  1323008  250005503  248682496
 4 P MS Data                251029504  636174335  385144832
NTFS at 0/32/33
filesystem size           1083392
sectors_per_cluster       8
mft_lcn                   4
mftmirr_lcn               67711
clusters_per_mft_record   -10
NTFS part_offset=1048576, part_size=554696704, sector_size=512
NTFS at 0/32/33
mft_lcn                   4
mftmirr_lcn               67711
     NTFS, blocksize=4096, 554 MB / 529 MiB
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
no_of_cluster : 98304 (2 - 98305)
fat_length 769 calculated 769
FAT32 at 67/144/14
FAT: cluster=2(0x2), pos=1093632
     EFI System               1085440    1290239     204800 [EFI System Partition] [NO NAME]
     FAT32, blocksize=1024, 104 MB / 100 MiB
NTFS at 82/90/9
filesystem size           248682496
mftmirr_lcn               2
NTFS part_offset=677380096, part_size=127325437952, sector_size=512
NTFS at 82/90/9
mftmirr_lcn               2
     NTFS, blocksize=4096, 127 GB / 118 GiB
FAT32 at 15562/31/22
FAT1 : 6206-7198
FAT2 : 7199-8191
Data : 8192-1023999
sectors : 1024000
cluster_size : 8
no_of_cluster : 126976 (2 - 126977)
fat_length 993 calculated 993
FAT: cluster=2(0x2), pos=250013696
     MS Data                250005504  251029503    1024000 [NO NAME]
     FAT32, blocksize=4096, 524 MB / 500 MiB
NTFS at 15625/220/20
filesystem size           385144832
mft_lcn                   2822382
mftmirr_lcn               2830833
NTFS part_offset=128527106048, part_size=197194153984, sector_size=512
mft_lcn                   2822382
mftmirr_lcn               2830833
     NTFS, blocksize=4096, 197 GB / 183 GiB
NTFS at 39600/5/22
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                635090945  636174336    1083392
     NTFS found using backup sector, blocksize=4096, 554 MB / 529 MiB
NTFS at 39600/5/22
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                636174336  637257727    1083392 [Recovery]
FAT32 at 39667/117/3
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT: cluster=2(0x2), pos=637265920
     MS Data                637257728  637462527     204800 [NO NAME]
NTFS at 39680/52/53
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                636379137  637462528    1083392
NTFS at 39680/52/53
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                637462528  638545919    1083392 [Recovery]
FAT32 at 39747/164/34
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT: cluster=2(0x2), pos=638554112
     MS Data                638545920  638750719     204800 [NO NAME]
NTFS at 39760/100/21
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                637667329  638750720    1083392
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                638750720  639834111    1083392 [Recovery]
FAT32 at 39827/212/2
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT: cluster=2(0x2), pos=639842304
     MS Data                639834112  640038911     204800 [NO NAME]
NTFS at 39840/147/52
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                638955521  640038912    1083392
mft_lcn                   45141
mftmirr_lcn               2
     MS Data                640038912  641122303    1083392 [Recovery]
FAT32 at 39908/4/33
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 39908/4/33
FAT: cluster=2(0x2), pos=641130496
     MS Data                641122304  641327103     204800 [NO NAME]
block_group_nr 25
recover_EXT2: s_block_group_nr=25/518, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 16974592
recover_EXT2: part_size 135796736
Filesystem created: Sat Apr  9 09:35:04 2022
     Linux filesys. data    636174334  771971069  135796736
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 69 GB / 64 GiB
NTFS at 48052/249/6
filesystem size           204800000
mftmirr_lcn               2
     MS Data                567171073  771971072  204800000
     NTFS found using backup sector, blocksize=4096, 104 GB / 97 GiB
NTFS at 48052/249/6
mftmirr_lcn               2
     MS Data                771971072  976771071  204800000 [MEDIA]
     NTFS, blocksize=4096, 104 GB / 97 GiB
   P EFI System               1085440    1290239     204800 [EFI System Partition] [NO NAME]
   P MS Data                250005504  251029503    1024000 [NO NAME]
echo "0 1083392 linear /dev/sda 2048" | dmsetup create test0
echo "0 204800 linear /dev/sda 1085440" | dmsetup create test1
echo "0 248682496 linear /dev/sda 1323008" | dmsetup create test2
echo "0 1024000 linear /dev/sda 250005504" | dmsetup create test3
echo "0 385144832 linear /dev/sda 251029504" | dmsetup create test4
echo "0 204800000 linear /dev/sda 567171073" | dmsetup create test5
echo "0 1083392 linear /dev/sda 635090945" | dmsetup create test6
echo "0 135796736 linear /dev/sda 636174334" | dmsetup create test7
echo "0 1083392 linear /dev/sda 636174336" | dmsetup create test8
echo "0 1083392 linear /dev/sda 636379137" | dmsetup create test9
echo "0 204800 linear /dev/sda 637257728" | dmsetup create test10
echo "0 1083392 linear /dev/sda 637462528" | dmsetup create test11
echo "0 1083392 linear /dev/sda 637667329" | dmsetup create test12
echo "0 204800 linear /dev/sda 638545920" | dmsetup create test13
echo "0 1083392 linear /dev/sda 638750720" | dmsetup create test14
echo "0 1083392 linear /dev/sda 638955521" | dmsetup create test15
echo "0 204800 linear /dev/sda 639834112" | dmsetup create test16
echo "0 1083392 linear /dev/sda 640038912" | dmsetup create test17
echo "0 204800 linear /dev/sda 641122304" | dmsetup create test18
echo "0 204800000 linear /dev/sda 771971072" | dmsetup create test19
ntfs_mst_post_read_fixup_warn: magic: 0x7d30407e  size: 1024   usa_ofs: 26795  usa_count: 56348: Invalid argument
Record 0 has no FILE magic (0x7d30407e)
 2 P EFI System               1085440    1290239     204800 [EFI System Partition] [NO NAME]
 4 P MS Data                250005504  251029503    1024000 [NO NAME]
 5 P MS Data                251029504  636174335  385144832
SIGINT detected! TestDisk has been killed.
Fortunately, I know the start and end sector for this partition so I created a new partition with these sectors.
I tried to list the files, backup BS, rebuild BS, chkdsk but can't access the data on it. I just want the data out of this single partition and I don't care about the other partitions on it. How can I access the data on this partition now?
Re: Can't access the partition I added in testdisk.
Iqbroly wrote: 14 Apr 2022, 02:23 Current partition structure:
SIGINT detected! TestDisk has been killed. [/code]
I can only see that you added a partition. I have no idea why your "other" partition is missing - by the way there are four other ones.
Iqbroly
#3 Post by Iqbroly »
I created a partition with sectors start= 251029504 and end=636174335. This was the partition where my important data is present. Is there a way to boot this partition?
You don't have to boot from your partition to rescue data from it.
This is description is not sufficient: "but can't access the data on it"
Use the rescue media part from you operating system to repair your system.
