WD passport, fubar again, 2nd one
norse51
#1 Post by norse51 »
I received a WD Passport 750 gb as a gift, and it ended up crapping out big time...so WD sent me a 1tb one.
I've made my own external with a 3rd party housing and a Seagate drive which is holding steady...so I've only been using the WD 1TB as my backup for my backup drive. Well, guess what, crappy WD does it again. Went to connect it yesterday and it say drive "needs to be formatted".
Using TestDisk, I can see that all of my data is still there. It seems some of the partition data got corrupted..and based on TestDisk it seems it might not even be the NTFS data, but FAT data.
After a Deeper Search, here is my resulting screen in TestDisk:
Any ideas or recommendations? I'd appreciate it!
Here is my log data from before the deeper scan:
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
OS: Windows XP SP3
Compilation date: 2012-08-14T11:59:29
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000175828992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000175828992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249949808640
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2048
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=26214400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=1000174780416
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST9250421ASG, FW:DE14
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512 - WD My Passport 071A, FW:2019
Drive D: - 2048 B - CHS 1 64 32, sector size=2048 - PLDS DVD+-RW DU-8A2S, FW:4D12
Drive I: - 26 MB / 25 MiB - CHS 6 64 32, sector size=2048 - WD Virtual CD 071A, FW:2019
Disk /dev/sdb - 1000 GB / 931 GiB - WD My Passport 071A
Analyse Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121597 255 63
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 121597 200 11 1953466368 [My Passport]
NTFS at 0/32/33
filesystem size 1953466368
mftmirr_lcn 2
file_pread(5,8,buffer,1953468416(121597/200/12)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1953468416(121597/200/12)) ReadFile The drive cannot find the sector requested.
file_pread(5,15,buffer,1953468417(121597/200/13)) lseek err Invalid argument
file_pread(5,3,buffer,1953468432(121597/200/28)) lseek err Invalid argument
file_pread(5,3,buffer,1953468479(121597/201/12)) lseek err Invalid argument
file_pread(5,8,buffer,1953468495(121597/201/28)) lseek err Invalid argument
file_pread(5,11,buffer,1953468542(121597/202/12)) lseek err Invalid argument
file_pread(5,2,buffer,1953470464(121597/232/44)) lseek err Invalid argument
norse51
Re: WD passport, fubar again, 2nd one
#2 Post by norse51 »
Hello all,
After I posted this, the drive began working again as normal...after the Deeper Search finished. Very strange, but at least it's up and running now.
norse51
#3 Post by norse51 »
Well, it looks like I spoke too soon...because the problem is back again today. Any ideas?
If the disk works again, try to clone it in the mean time as described in
