Hanging at "Quick Search"
uqbar
#1 Post by uqbar »
Hi all.
I am on Archlinux and the disk to be recovered is attached to an external USB adapter.
I have no way to create a local disk image as I don't have enough room.
I can actually and successfully access one of the partitions, but I am interested into another one.
testdisk is hanging after I select "Analyse" and then "Quick search": no debug output is written to the log file.
The process is reported in "D+" status, which means "uninterruptible sleep (usually IO) in foreground".
iotop shows there is no relevant I/O happening.
Any hint?
This is all I can get in the log file:
Using locale 'LC_CTYPE=it_IT.UTF-8;LC_NUMERIC=it_IT.UTF-8;LC_TIME=it_IT.UTF-8;LC_COLLATE=C;LC_MONETARY=it_IT.UTF-8;LC_MESSAGES=en_US.UTF-8;LC_PAPER=it_IT.UTF-8;LC_NAME=it_IT.UTF-8;LC_ADDRESS=it_IT.UTF-8;LC_TELEPHONE=it_IT.UTF-8;LC_MEAS>
Sat Apr 23 11:09:22 2022
Command line: TestDisk /log /debug /dev/sdc
OS: Linux, kernel 5.17.4-zen1-1-zen (#1 ZEN SMP PREEMPT Wed, 20 Apr 2022 18:29:30 +0000) x86_64
Compiler: GCC 11.2
ext2fs lib: 1.46.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.3
User is not root!
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - TOSHIBA MQ01ABF050
Disk /dev/sdc - 500 GB / 465 GiB - TOSHIBA MQ01ABF050
Partition table type: EFI GPT
New options :
 Dump : No
 Align partition: Yes
 Expert mode : Yes
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976773167 (expected 976773167)
hdr_lba_start=34
hdr_lba_end=976773134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 2 P MS Reserved               534528     567295      32768 [Microsoft reserved partition]
 5 P MS Data                390711296  976773119  586061824 [Basic data partition]
 1 P EFI System                  2048     534527     532480 [EFI system partition]
 3 P MS Data                   567296  389689343  389122048 [Basic data partition] [OS]
 4 P Windows Recovery Env   389689344  390711295    1021952 [Basic data partition]
Re: Hanging at "Quick Search"
If nothing is written to the logfile, where is the your enclosed log file coming from?
Use the most recent version of Testdisk and try out running Testdisk with admin rights.
