Deeper search backup?
Deleted User 16632
#1 Post by Deleted User 16632 »
Hello! I ran a deeper search on the hard drive that I wanted to recover files from but once it was complete, I accidentally exited the page while looking through the folderss. Can I find the results of the deeper search anywhere, or do I have to start the whole process all over again? If so, is there any way that I may save the results so that this doesn't happen again?
Alternatively, I've also tried using the Advanced option but only the options of "Superblock" and "Image creation" appear, not "List". Is there a reason for this?
Thanks!
Re: Deeper search backup?
evelyn wrote: 26 May 2022, 12:22 Hello! I ran a deeper search on the hard drive that I wanted to recover files from but once it was complete, I accidentally exited the page while looking through the folderss. Can I find the results of the deeper search anywhere,
No, not that I am aware of.
Yes.
No.
You are asking for an explanation of missing features that you personally expect? Are the people supporting Testdisk supposed to justify that it does not comply with your wishes?
I consider your question as pretty rude.
I feel like you did not operate Testdisk as carefully as necessary. Is there a reson for this?
How is this?!
Your attitude is embarassing.
You are free to modify the source code, it is available on this site.
If you want to incorporate new features feel free to ask the programmer for a quote.
