I am trying to recover a partition on a Linux system. The disk should have 2 partitions and I can even access the second one from command another file system. I run testdisk, run both searches but can not see neither partition. All I get is Input/output error. Here are the first lines of the log file:
Disk /dev/sdc - 1500 GB / 1397 GiB - ATA ST31500341AS
Analyse Disk /dev/sdc - 1500 GB / 1397 GiB - CHS 182401 255 63
Partition: Read error
file_pread(6,16,buffer,32(0/0/33)) read err: Input/output error
file_pread(6,3,buffer,48(0/0/49)) read err: Input/output error
file_pread(6,3,buffer,95(0/1/33)) read err: Input/output error
file_pread(6,8,buffer,111(0/1/49)) read err: Input/output error
file_pread(6,11,buffer,158(0/2/33)) read err: Input/output error
file_pread(6,2,buffer,2080(0/33/2)) read err: Input/output error
Could somebody please help me on what else can I do?
Thanks!
Can not recover lost partition, Input/output error
justonwuckert
Re: Can not recover lost partition, Input/output error
I don't understand what "from command another file system." should mean.
