Hi all!
I need to recover one file from a disk I formatted, pitifully the online backup failed (google workspace problems) after I reinstalled linux on the laptop, but I haven't done much on it (and it was almost full before the reinstall) so I know the file I need is probably there.
My problem is the recovery process said it takes around 72 hours, the laptop is old and I the process halted at around 1/2-3/4 (three times now). The file is not there.
Is there anyway to start the process from the end of the disk? that way it would be no problem if I get an incomplete process as the entire disk would have being scanned! I suspect my file is near the end of the disk.
I thank you in advance for any reply!
run photorec backwards?
Re: run photorec backwards?
No, there is no backward running mode.
Fingerprints of files are typically located at the beginning of a file. The cluster that belong to a file are typically showing an increasing cluster number.
Therefore the mode of operation you would personally like is not useful at all.
Use smartmontools to check for possible unreadable sectors. Depending on the result it might be a good idea to duplicate your drive using ddrescue as described in the manual.
Once you have a working copy you can be sure that the work of Photorec is not delayed by unreadable sectors.
Ok
I'll do it as you suggest! just need to find more disk space for the duplication
Thanks for your answer
