TestDisk 7.1 - No Option to select Log File Creation
RioLuna
#1 Post by RioLuna »
TestDisk 7.1
First screen is drive selection.
There is not an option to select log file creation.
Please assist.
>Disk /dev/nvme0n1 - 2048 GB / 1907 GiB
Re: TestDisk 7.1 - No Option to select Log File Creation
Use the most recent version.
RioLuna
#3 Post by RioLuna »
@recuperation - Thank you for your reply
Just to clarify...
Current released version as of today is 7.1
Are you recommending to use instead Beta version 7.2-WIP?
Thanks.
RioLuna
#4 Post by RioLuna »
I am using most recent version of SystemRescue (9.03) which apparently includes Testdisk v7.1
#5 Post by recuperation »
RioLuna wrote: 26 Jun 2022, 20:53 @recuperation - Thank you for your reply
Just to clarify...
Thanks.
Yes, do not worry about the term "beta".
