SD card got corrupted: trying to reformat: do not care about files or recovery
zoop
#1 Post by zoop »
hey folks it's been quite a journey finding this forum. I hope you are all having a fine day and able to help me.
somehow I've corrupted a SD card to the point it is not readable by windows or linux. (I'm using Mint)
I have tried using cmd to reformat the drive with failures and fianlly found my way to the software TestDisk
I've also read the testdisk pfd (very informative thanks for that! it may come in handy)
I've followed 7.4 Repairing FAT32, exFAT and NTFS boot sector using TestDisk
To be clear: I don't care about the data on this drive. I'm just trying to give life back to the SD card so that it's usable again
here's what I understand
The drive doesn't show up at all in Windows
The drive shows up in Linux under the Gparted (or disks) as a raw format.
Opening testdisk (in linux) shows
>Disk /dev/sdf - 15 GB / 14 GiB - Generic STORAGE DEVICE
Here I'm hitting proceed
it's auto-choosing intel so I'm continuing with that.
chooses Intel
it now reads
     CHS 15193 64 32 - sector size=512
here per the instructions I'm choosing Advanced.
No Partition Available
Through trial and error I've found that writing a copy of MBR
to the first sector now gives the following options
Disk /dev/sdf - 15 GB / 14 GiB - CHS 15193 64 32
> 2 * Sys=44               559240  34  5 1118481   4  8 1145324612
  1 * Sys=4C               559244  34  5 1131626   4  8 1172237380
I'm not sure what to do here as the only options are "image creation" "quit" and "type"
I've saved each partition to a image in a folder on the Linux computer but not sure what to do from here.
Thanks for any support or guidance you are able to give!
PS: if
I'm hitting Analyse the following message dispalying
[b]Partition sector doesn't have the endmark 0xAA55[/b]
here I'm hitting quick search
it runs Analyse cylinder
and I get the following
 Warning: Bad starting head (CHS and LBA don't match)
  3 * Sys=44               559240  34  5 1118481   4  8 1145324612
  4 * Sys=44               559240  34  5 1118481   4  8 1145324612
    Next
>[Quick Search]  [ Backup ]
Re: SD card got corrupted: trying to reformat: do not care about files or recovery
Testdisk is a recovery tool and not a format tool. Therefore it is not suitable for your format intentions.
zoop
#3 Post by zoop »
Allright that makes perfect sense.
Thanks for the answer. Do you know of any tools that can help in formatting a SD card that is messed up?
If your card is broken no software will help you.
https://www.sdcard.org/
