Hello, I'm currently running Phtotorec on a hdd I accidentally formatted with the WIndows Media Creation Tool.
1. Can I pause and resume the recovery? If so how do I quit the scan, Ctrl+C?
2. It found a bunch of .txt files that I think might be pdfs. Is there a fast way to restore the pdfs? I'm talking hundreds of files.
3. It found a lot of .mpg files, when played they either show nothing or maybe 1 frame or so. What are they?
Photorec recover data from old hdd. Pausing and restoring pdfs
Re: Photorec recover data from old hdd. Pausing and restoring pdfs
Press the "return"-key.0bArcane wrote: 17 Jul 2022, 11:09 Hello, I'm currently running Phtotorec on a hdd I accidentally formatted with the WIndows Media Creation Tool.
That is what you claim.2. It found a bunch of .txt files that I think might be pdfs. Is there a fast way to restore the pdfs? I'm talking hundreds of files.
Thank you for believing in my foreseeing abilities!
